Stealth Ram IAC
Old Feb 8, 2005 | 01:54 PM
  #16
Jon A's Avatar
Re: Stealth Ram IAC
Originally Posted by Hot Rod Hawk
It's quite odd when you switch to another type of intake on a LT1 that funny split BLM issue strangely has exited the datalog info once you take that funky "profile" the injector balance tables are loaded with, but that's another topic.
That's the end result I was getting at. And it brings up another question:
For those of you who have experience setting individual cylinder fuel trims properly on an LT1 or regular SBC with any other type of intake, what is the common variance from cylinder to cylinder?
Is it common for #1 & #2 to need 4.6% more fuel than #7 & #8 at WOT? Is that something that would concern you?
How about 13.2% more fuel for #1 & #2 than for #7 & #8 at idle? Normal?
That's how the stock LT1 PCM is programmed. One can only assume the people at GM who did this set them that way through proper testing.
Old Feb 8, 2005 | 07:40 PM
  #17
Hot Rod Hawk's Avatar
Re: Stealth Ram IAC
Normal...
with all the air entering the front of the intake those holes are leaner and just the opsite [sp?] for the back of the intake. Another thing that will help to get them running closer is to ditch the factroy fuel rail that feeds into one rail crossing over to the other bank where it's dead headed on the regulator. It works but feeding both rails the supply then into a reg from each bank cleans up the split further.
Just what I noticed when I did this to the LT1 manifold before my SP days.. it stop nipping plugs on the bottle when I did this
G-BODYT56
Jan 14, 2022 11:14 PM
Stephen68
Oct 16, 2015 03:50 PM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
CARiD
Sep 30, 2015 05:44 AM
