SR Camshaft Selection Help Needed!!!
Besides that.....drives great.
OK......you guys now can fight some more. Who's turn is it? I forgot.
Well i put in my cam request to Cam motion and we will see what they come back to say. In the mean time im going to keep contacting others and see what they recommend & wait for others to chime in this thread.
I do have a question what does this + # mean after the LSA? For example like 1racerdude said 112 + 4 what does the + 4 represent?
Alright got my cam specs from cam motion they recommend
A 247/253 .683/.664 on a 110 LSA the part number shows the last numbers being a 110+4 so i don't know it's a true 110 + 4 or if it's just part of the part number.
What do you guys think of the cam? it's similar in duration to the comp cam recommendation but the lift is different along with the LSA. Im going to plug it in and see what the DCR will come out to be.
Haven't done business with Cam Motion in 7-8 years after my solid lifter breakage episode so things may have changed but it seems every time I got cam spec's from them it was different. Perhaps it's just me....I'd expect them to be the same or at lease very similiar for the same setup.
I had the same experience with Comps "Cam help line". I think the people just type crap into the computer and read what it spits out with no real knowledge of what really going on. I called 4 times, gave the same info and got 4 different cam recommendations. Maybe its better now but it wasn't when I tried it a couple years ago.
Sounds like a nice cam for your application. Not sure what your specifics are but Cam Motion wont steer you wrong. Their cams usually have alot of lift for some reason. Those specs are probably with 1.6 rockers also. If you step back to a 1.5 it will lower the lift quite a bit. I say the more lift the better
My Cam Motion cam has more lift on the intake also : .686" I and .674" E
Just make sure you check PTV clearance.
