Solid Roller P/V clearance measuring
Old Sep 26, 2005 | 02:15 PM
atljar's Avatar
I was trying to measure my Piston to valve clearance this weekend on the solid roller I am putting in.
I tried putting piston at TDC, and zero lashing. Then I pushed down the valve against a checker spring and inserted .100 thickness of feeler gauges.
That really didnt work because they kept falling out while i was rotating the engine and were rubbing not only on the stem, but also retainer.
I next went to TDC, and inserted the feeler gauges first (.100" worth) and zero lashed it. I then removed the feeler gauges, counting turns of the lock nut on the rocker arm to get back to true zero lash. I then added that many turns past zero lash opening the valve (should have been .100 more open).
Here is the question. I only measured 3/4 a turn for .100 of an inch on my rocker nut.
On shoebox's site, for 7/16 studs he has a 1/2 flat = .00416, 6 flats per rotation.
.00416 x 2 = 1 flat = .00832
.00832 x 6 flats = 1 rotation = .04992
Using his numbers would mean 2 full turns for .100" . I cant imagine I would have been that far off.
Old Sep 26, 2005 | 03:23 PM
SStrokerAce's Avatar
Re: Solid Roller P/V clearance measuring
Did you put some clay or playdoh in the piston valve reliefs and spin the motor over? If you measure that thickness after you do it you will be pretty close. RMRE has a really in depth way of doing it but it requires special valves and a ton of work.
Bret
Old Sep 26, 2005 | 03:52 PM
1racerdude's Avatar
Put the clay in the v reliefs and make smooth with the top of piston. Put oil or baby powder on the clay(to keep it from sticking to valve). adjust valves,roll engine twice,remove head,cut clay and measure and that is your P/V clearance..080 I-.100 E min.
Old Sep 26, 2005 | 04:40 PM
atljar's Avatar
Heads are still on the car. Trying to avoid pulling them to do the clay method.
Old Sep 26, 2005 | 04:52 PM
1racerdude's Avatar
Ok,put a degree wheel on it and start at 40*BTDC and check it every degree like you were with the soft springs and a dial indicator and pushing on them until ya reach 40*ATDC.This is with both valves adjusted and both with soft springs.
Do it two rev's to get the overlap cycle ,and make sure ya find "0" correctly.
Old Sep 26, 2005 | 07:08 PM
atljar's Avatar
OK that makes sense.
Where is the best place to set up the tip of the dial indicator? On the flat (non concaved) part of a retainer?
Old Sep 26, 2005 | 07:18 PM
1racerdude's Avatar
Yea, any place that will give ya the measurement the valve travels to the piston.
Old Sep 26, 2005 | 08:16 PM
atljar's Avatar
thank you larry and bret
Old Sep 26, 2005 | 08:47 PM
1racerdude's Avatar
Anytime
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
