Solid roller lifters/hyd cam?
Old Dec 24, 2005 | 11:06 PM
  #16
atljar's Avatar
Re: Solid roller lifters/hyd cam?
Ya but wont the advertised lift used change from company to company as much as it does type? I thought thats why the standardized .050 was created.
Either way, I was just trying to over simplify things. Sometimes I suppose, that in the end, that makes things worse.
Happy Holidays!
Old Dec 25, 2005 | 11:08 AM
  #17
SStrokerAce's Avatar
Yeah the advertised can move around a lot. If you plot a SR lobe vs. a Hyd Roller lobe in a chart from a Cam Dr file you can see a lot of similarities if the lobes are the same .050 duration. Problem is the lash makes the Hyd run like a smaller cam due to that lash. That's why the winners of this years Engine Masters put more lash into their setup before their final pulls.
Bret
Old Dec 25, 2005 | 11:34 AM
  #18
atljar's Avatar
Confused now....
Put more lash into it? Wouldnt that lessen the cam?
Old Dec 25, 2005 | 12:58 PM
  #19
Yep that's exactly why they do it. It also bumps the DCR a good amount.
The 509's were running 260 deg cams at .050 with over .700" lift and upwards of .800"
Thats a TON of cam for a 2500-6500rpm range with the right sized heads.
When you add lash you pull up the TQ curve almost everywhere below HP peak. A 1-2 ft lbs gain everywhere is worth it when you are really close to the next guy in total score in that competition. It's just not going to live very long but 3 dyno pulls isin't too much.
FWIW Lennart Bergquist who won this year is no dummy. His shop car is a 357cube Comp Elm that's over 1000hp NA. At least it takes that much power to move a 2300lbs car 182mph in the 1/4.
Bret
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
95chwagon
Jan 13, 2015 09:19 PM
Wicked
Jul 25, 2002 04:19 PM
Ed95Pont
Jul 23, 2002 08:26 AM
