Small block 396
Old Mar 18, 2004 | 10:46 AM
  #16
racer7088's Avatar
Arrow
What value are you talking about, they cost the same basically unless you're looking at all cast stuff. I don't like small base circles and the 383 is a tiny bit better there but it's no problem if you know what you're doing.
Old Mar 18, 2004 | 11:53 AM
  #17
SStrokerAce's Avatar
Originally posted by racer7088
Rod side loading issues are what people that can't build engines use as an excuse for bad machine work usually. I'm NOT talking about Bret in particular though.
Come to think of it the ones I had to tear down were beat on motors anyways, and the machine work on the blocks was horrible.
The longer rod is still going to help side loading, and as Rich said most big HP motors aren't going to see lots and lots of miles anyways.
Bret
Old Mar 18, 2004 | 12:32 PM
  #18
racer7088's Avatar
Thumbs up
Bret I agree with you that shorter rods do load the walls more. There's nothing to debate there but it's no where near as bad as people think. The angularity is not much change and it's really a triangle based on half the stroke and the whole rod length so it's not quite as bad as people usually believe.
The skirts on a 14 to 1 SBC will almost always show wear to one side but it isn't always the thrust even on the same engine on different sides and people always say it's from rod angle when it's from the offset or heavier dome on one side. Also if you do a good job of chamfering the tops and bottoms of the cylinder this type of wear out the bottom is greatly reduced and almost eliminated depending on the piston type and skirt or wall clearance.
We spend a huge amount of time on detail work and it makes a difference. I see stuff go out and come back in all the time. On last years LS1Tech series Top Gun Champion Rick Intrau's 396 LT1 with "around" a 300 shot running 150 in the quarter at a pretty heavy weight, the skirts looked great and they went through hell. That was with a 6 inch rod and all the pistons are there at 1.0625 CH. I'd rather see the taller piston with the 5.85 but that's what he had.
Old Mar 19, 2004 | 01:07 PM
  #19
mtxpert's Avatar
This is a 3.875 stroke with Eagle H-beams on a road race engine that makes 465 at the wheels and is still running. It wasn't that bad.
Here's my horrendous pics from a motor built by 1st Performance in Mesa, AZ.
Here's my pics:
http://azsupersport.com/images/396oo...oops%20004.jpg
http://azsupersport.com/images/396oo...oops%20011.jpg
http://azsupersport.com/images/396oo...oops%20012.jpg
http://azsupersport.com/images/396oo...oops%20014.jpg
http://azsupersport.com/images/396oo...oops%20015.jpg
Your information is very disappointing to me as he had me convinced the clearancing issues were my fault for supplying him the Eagle H beam rods.
Mike
Old Mar 20, 2004 | 01:17 AM
  #20
racer7088's Avatar
Arrow
Yep that is simply a shop that doesn't know what they're doing or maybe it was their first one or something? I've never done that on any SBC so far and I've done 4.000 strokes too and one 4.125 as well.
The newer Eagles have shorter bolt heads which helps too.
Old Mar 20, 2004 | 09:49 AM
  #21
SS MPSTR's Avatar
Not only is your machinist/engine builder wrong - he's dead wrong and borderline incompetent.
Old Mar 20, 2004 | 10:02 AM
  #22
OldSStroker's Avatar
You are being too nice.
Old Mar 24, 2004 | 01:17 AM
  #23
SSlammedlt-4's Avatar
Eagle H beam rods + 3.875 stroke = water jackets...
Do a 383 instead if you want H beam rods.
Trust me on this one.
Mike
Not here
Old Mar 24, 2004 | 07:25 PM
  #24
john35thss's Avatar
I just finished clearancing my 396, I used a cola crank with scat h beams. It was scary getting enough clearance but I didn't hit water filled block with hardblock to bottom of freeze plugs just to be sure.
John Carpico
F'n1996Z28SS
Jun 3, 2015 09:39 AM
Nellsw88
May 26, 2015 05:55 AM
geinsteder
May 6, 2015 06:02 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
