Is this safe compression for boost?
Old May 30, 2003 | 01:09 PM
bunker's Avatar
Basicly my heads were ported & milled .010, after porting & milling they were CC'd & came out to 54cc, with the combination of Fel-Pro 1074 gaskets .039 thickness I calculated my compression ratio to be 10.9:1 is is .49 higher then stock. I'm thinking of running boost about 6 pounds hopefully, do you guys think I'll be ok?
I figured this, even ATI 8lb blowers say they are for 93-97 Camaros/Firebirds, now I know the LT4's came with 10.8:1 stock, do they mean 8lbs intercooled will be fine with LT4's aswell then?
Also, what cam do you guys recommend? Reason being is I'm looking at the XE 224/236 .502/.520 lift w/1.5 rockers on 114lsa, I'll be running 1.6 rockers, should I go higher on the lift & LSA?
And will an intercooler help prevent detonation?
here is my head flow numbers:
LIFT...... INT......EXH
.100......74...... 69
.200......127......121
.300......191......152
.400......254......183
.500......283......192
.600......287......201
Old May 30, 2003 | 01:48 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
why not open the chambers more?I bet they would go 60cc..
Old May 30, 2003 | 01:55 PM
bunker's Avatar
Well the heads are on & I really don't have the convinience of a house to this is for the hundredth time I dunno what do you think as is right now? Your heads are still sitting here Jordon, maybe one day I'll think of something for them
Old May 31, 2003 | 09:46 AM
Zero_to_69's Avatar
IMO, adding forced induction on such a high compression is going
to limit the use of the supercharged. It will only get a small percentage
of it's potnential.
At some point throughout the RPM band when volumetric efficiency
is near and above 90%, I think you're going to run into some
nasty pre-ignition.
An intercooler will most certainly reduce the chance of detonation.
Running a little fatter on fuel will also help reduce detonating.
What sort of ignition do you have and spark plug heat range?
Plug temperature is going to play a huge role in performance
under boost.
With some tweaks in spark timing retard, plug temperature and
proper fuel ratio, you could probably get away with 6 PSI.
I'm not an expert, but I understand the variables involved. Without
flow numbers for the entire assembly, it's tough to determine
how much cylinder pressure you're going to end up with and
how safe 6 PSI will be.
Old May 31, 2003 | 11:52 PM
menlatin's Avatar
hey, spend $300 for a water injection kit, and you'll be just fine. PLus you get nice clean chambers and exhuast.
Old Jun 2, 2003 | 05:15 AM
bunker's Avatar
Hmm... I'm using NGK TR6's & LS1 ignition coil per cylinder conversion so my ignition is very very strong
Old Jun 2, 2003 | 09:10 AM
Jesse_Boyer's Avatar
i believe menlatin wants you to use a water injection kit to reduce combustion chamber temps... thus reducing detonation.
Old Jun 3, 2003 | 01:48 AM
bunker's Avatar
can I get a link to this water injection stuff? I belive its called ADI right? Anti detonation injection, same thing small engine aircraft with Turbos use, didn't know we had kits like that avaliable for us
Old Jun 3, 2003 | 08:53 AM
bunker, you might want to talk to rskrause. he's got water or alky injection (or used to).
Mikes 1994 z28
Oct 10, 2015 07:55 AM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
rideordie
Sep 7, 2015 08:22 AM
Henson071
Aug 4, 2015 09:32 AM
