Replacing valve springs *on* engine...
Old May 14, 2005 | 01:34 PM
jimlab's Avatar
I've got an air fitting for the spark plug hole, I put cylinder #1 at TDC, apply 100 psi and I'm getting a constant small leak past the valves. I then compress the exhaust valve spring with a shaft-mount valve spring compressor, and get a big shot of air out the exhaust hole instead of the valve staying up and the locks popping loose... what am I doing wrong?
I'd pull the heads off the engine but I didn't want to have to remove the bases for my shaft rockers and remove the heads from an engine with only a couple dyno runs on it if I didn't have to, although it would probably make degreeing new cam a heck of a lot easier. Any ideas?
Thanks!
Old May 14, 2005 | 02:06 PM
OneFlyn95z28's Avatar
Re: Replacing valve springs *on* engine...
you need to break the retainers loose. I am headed that way if you would like me to stop by? I just did a valve spring change (Hot cam kit install) for a customer this week.
I will shot you a PM with my number if you are interested.
Ellis Groo
Speed Secrets
"The Secret to reliable performance!"
Old May 14, 2005 | 02:31 PM
SStrokerAce's Avatar
Yeah gotta break the locks loose.... I know it sounds crazy but hit the retainer (not the valve) with a dead blow to break the locks loose from the retainers... then you will compress the spring indepenant of the valve.
Bret
Old May 14, 2005 | 02:37 PM
Mindgame's Avatar
Yep, just smack em.
I use a piece of short pvc pipe so I can spread the *smack* all around the retainer but a well aimed dead-block hit will do it too.
-Mindgame
Old May 14, 2005 | 03:08 PM
OldSStroker's Avatar
Bret
Yeah, be careful not to damage any of those $400/set wavy Ti retainers...or, Heaven forbid, lose one in the process!
Old May 14, 2005 | 03:22 PM
Zero_to_69's Avatar
I just replaced my springs, retainers and locks.
I used a rubber mallet and hit the retainer as everyone mentioned above.
You'll hear loud pops until the locks break free. You'll hear the difference
once the retainer comes loose.
OAN: It is safe to leave the carburetor on the motor when using compressed
air? Will 100 PSI of air popping back up the intake runner ruin a power valve,
or anything (compared to back firing)?
Old May 14, 2005 | 06:57 PM
jimlab's Avatar
Thanks guys. Ellis stopped by and we discovered that the new springs don't fit over the seats on the heads, so...
So I'm heading to Sears to get a 3/8" 12-point deep socket set to get the last 3 @#*(@*% stud bolts that I can't get to with the springs on the heads. I needed some new tools anyway...
Old May 15, 2005 | 01:47 PM
Very nice ride you have there Jim! I would love to to it running down the road soon!
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
