Rant about "how much hp can my block take"
Old Dec 5, 2004 | 04:35 PM
  #31
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Re: Rant about "how much hp can my block take"
i think block fill is in order for me over the winter. do i need to pull the engine out of the car? i have top end off of the motor as it is right now.
thanks
taner
Old Dec 5, 2004 | 04:58 PM
  #32
Lonnie Pavtis's Avatar
Yes, removing the engine is necessary as the block fill will slightly distort the cylinder bores as it hardens & will likely require a slight hone to be sure the bores are round. The type & amount of fill as well as your cylinder wall thickness will change this amount of distortion, but you should be sure it has not runied any tolerances.
Did you get my e-mail by any chance?
Hope this helps.
Old Dec 5, 2004 | 06:05 PM
  #33
mls48341's Avatar
You may want to be able to rotate the block as well to insure even and
thorough filling.
Old Dec 5, 2004 | 06:25 PM
  #34
taner's Avatar
oh well **** filling the block till next time the block comes out! i planned on tearing it down NEXT winter, freshen bearings.
please resend lonnie, i think it was deleted accidentally
thanks guys!
taner
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
