purpose of POLISHING CON RODS?
Old Aug 31, 2002 | 03:04 PM
boosted-lt1's Avatar
Post purpose of POLISHING CON RODS?
Wondering what this process involves(polishing con rod beams) and why it is done. My best guess would be to say it removes casting flaws in a stock rod application. Even if that is the case how does that add to reliablity, and again, why would it be performed?
'95 CAMARO M6
VORTECH
STAGE II HEADS
CC-218-230-114
SPEC STAGE 3
MUFFLEX 4"
Old Aug 31, 2002 | 05:34 PM
89WS6L98's Avatar
Post
Polishing the beams removes "stress risers". Stress risers are high points, such as a seam from casting. Stress concentrates on points, or pointed areas. This can lead to cracks at the stress point, or "stress riser".
Reliability is improved when the areas prone to developing stress cracks are removed. Polishing does this.
Old Aug 31, 2002 | 07:16 PM
Post
thank you.
Old Aug 31, 2002 | 09:19 PM
arnie's Avatar
Post
<font face="Verdana, Arial" size="2">Polishing the beams removes "stress risers". Stress risers are high points, such as a seam from casting.</font>
Are you talking a casting or a forging?
That principle works for a forging. I question the use of cast rods for anything other than stock torque output. IOW, if you are going to the trouble, may as well go with forged.
I'll be back
Old Aug 31, 2002 | 11:57 PM
Post
ARNIE-
I realize the benefits of forged pieces over stock cast and also relaize by the time you are done making a stock/cast piece stronger you might as well go out and get some forged rods. I was just unclear of what the polishing process did but am clear on it now. thanks.
-scott
Old Sep 1, 2002 | 12:00 AM
Stephen 87 IROC's Avatar
Post
Polishing the rods is only the first step. They should then be balanced, shot peened and resized. After all that, some good rod bolts and the rods will take more abuse than the factory originally designed them for.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.349
Best MPH on a time slip: 119.7
Best corrected ET: 10.983
Altitude corrected rear wheel HP: 480
Best 60 foot: 1.546
Member of the Calgary Drag Racing Association
Old Sep 1, 2002 | 10:36 AM
Erik's Avatar
Classic Tech Moderator
Post
So what is shot peening then?
Old Sep 1, 2002 | 10:41 AM
Bud M's Avatar
Post
I've read about rods actually being weakened by polishing in certain cases but I don't remember the details.
1993 Z28 M6 3.23
LPE CAI with scoop, Hooker Shorties, Dynomax Super Turbo muffler, !TB, 160 Tstat, Jet fan switch, Accel 9000 wires
BMR STB, SFCs, LCAs, PHB
Momo Runner steering wheel, Pro 5.0 with Momo handle, MSD shift light
pics of my Z
Old Sep 1, 2002 | 12:50 PM
Post
Think of shot peening as sand blasting with small ***** of lead. It has the same effect as using a ball peen hammer. By hitting the entire rod you create tiny dimples all over it. This relieves stress from the metal. The rod must be then resized because shot peening will distort the metal.
Old Sep 3, 2002 | 12:01 PM
1Z2Z's Avatar
Post
I wouldn't classify shot peening as a stress relieving process. As you described, it blasts the surface and creates dimples, but the idea of shot peening is to toughen the surface by compacting the grain, much like a forging process does, and make it less susceptable to crack formation and growth. Mike
Old Sep 6, 2002 | 10:20 PM
Tiago's Avatar
Post
actually it creates resudual "negative" stresses in the metal, so that when its loaded normally under stress insidee the motor is will actually see a "zero" net stress, and when unnder maximum stress it would still be less then normal since the negative residual stress keeps it lower.
BADBIRD
Turboed, Intercooled, and NRT'd
http://tiago.phxchevy.com
AIM: Tiago 94FB
DOWN WITH THE SICKNESS
SICK-SIXX
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
