Pick-up Tube Depthness continued..
Old Jan 13, 2004 | 08:38 PM
97 RedSS's Avatar
What is the recommended distance the pick-up should be from the bottem of the pan?? Im hearing a few different numbers so I want to know what the engine builders suggest.
I didnt do the clay trick but my method should be just as accurate..
I measured the distance from the bottem of the block to the pick-up tube which measured to be 7.125".
Then I measured the distance from the bottem of the oil pan(where the pickup would be) to the top of the oil pan and came up with 7.500"
That tells me w/o the gasket the pickup would be .375" off the bottem of the pan.
The gasket measures .250" so now Im off the bottem of the pan .625" but that is with an uncompressed gasket.
Looks like Im gonna have to find a way to lower the pickup tube but I want to hear some feedback first..My tube is welded on but Im sure I can tap it down a lil bit if needed.
Cody
Old Jan 13, 2004 | 10:13 PM
XLR8N6's Avatar
Re: Pick-up Tube Depthness continued..
You should set it to 1/4" to 3/8" clearance.
Old Jan 13, 2004 | 10:20 PM
97 RedSS's Avatar
Is that measurement made from the Screen or the Tube?
Cody
Old Jan 14, 2004 | 02:10 AM
XLR8N6's Avatar
Cody
The pickup screen/screen housing (whichever is lower).
Old Jan 17, 2004 | 09:56 PM
97 RedSS's Avatar
I set the clearance to .250" off the bottem of the pan and Ill let you guys know if I am still experiencing a slight drop in oil psi above 4k. My pick-up was .650" off the bottem
It was only dropping from 60 psi to 55 psi, but I really didnt feel comfortable with it dropping. Hopefully, I solved the oil pressure problem and I went ahead and added a brand new felpro oil pan gasket since it was leaking just a lil
I did the canton pan by myself in only 8hrs of work.
Cody
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Slayer
Jul 4, 2015 03:06 PM
