Oilpan ?
Old Aug 28, 2004 | 11:25 AM
mrz28 73/97's Avatar
Oilpan ?
Hello everyone I have a lowered 97 SS which I will soon be installing my 383 along with BMR k-member and Pacesetter lt's and the question I have is concerning oilpan to ground clearance with a lowered car.
I have a choice of oilpans I can use, either the standard Canton 5qt or a Milodon 7qt kickout style pan. I'd prefer to use the Milodon for the extra capacity and the horror stories I've heard about Canton pans leaking, but I'm concerned about ground clearance.
I've got a set of regular sbc longtubes hanging on the engine while it's on the stand and it looks like the sump of the Milodon pan is about 1" lower than the bottom of the headers.
Should I be concerned, because if it's going to be a problem I'd rather change the pan with the engine on the stand.
Any feedback will greatly be appreciated.
Old Aug 28, 2004 | 07:58 PM
NVMYZ28's Avatar
Re: Oilpan ?
not really an advanced tech sorta question - but I am gonna say:
If its a car you plan to drive normally on the street - you will have issues if the pan is 1" lower then the lowest part of your longtubes. On a lowered F-body with longtubes - your bound to scrape the exhaust slightly once in awhile. With an oil pan being one inch lower then the lowest part of my exhaust - I would be nervous in a "Driver" setup.
Track only is a completly different story.
Old Aug 28, 2004 | 09:46 PM
Re: Oilpan ?
Thanks for the info, I think I'll change to the Canton oilpan.
PostalZ
Parts Wanted
Mar 26, 2006 11:13 AM
2fbodies2NV
3rd Gen / L98 Engine Tech
Mar 13, 2006 02:57 PM
roughrider20
Jan 25, 2006 10:40 PM
9730thcam
Jan 23, 2005 07:33 PM
dust6928
Apr 1, 2003 10:37 AM
