Oil Pump Drive gear
Old Apr 20, 2005 | 11:15 PM
Heatmaker's Avatar
Advanced Member
Oil Pump Drive gear
Do LT-1's use an Oil pump drive gear, and if so what aftermarket version is reccomended for a HV Melling pump?
Old Apr 20, 2005 | 11:51 PM
SStrokerAce's Avatar
Re: Oil Pump Drive gear
Yep they do.... you don't need a aftermarket one unless your cam is not compatable with it.... and all the Comp Billet cams have a everwear gear that's compatable with the stock gear.
Bret
Old Apr 21, 2005 | 08:30 AM
Heatmaker's Avatar
Advanced Member
how strong is the stock gear?
Old Apr 21, 2005 | 08:36 AM
NOMAD's Avatar
Stock gear is strong. All it's needed for is driving the oil pump. Onyl suggestion I've got is to use a ARP oil pump drive shaft.
-Shannon
Old Apr 21, 2005 | 09:31 PM
Heatmaker's Avatar
Advanced Member
It's on order... thanks a bunch for hte help.
Old Apr 21, 2005 | 10:00 PM
sleepy_z28's Avatar
Since my oil pump drive had some miles on it, I replaced it with a new one from GM when I had the 383 built with the different cam. I also run the Meling HV oil pump and an ARP drive shaft.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Elcojoe
Nov 17, 2014 10:27 PM
