Oil pan fabrication...
Old Feb 10, 2004 | 12:34 AM
noc_81's Avatar
First of all, I couldn't figure the best place to put this post, so please move it if I chose wrong...
I don't know if I am skilled enough to fabricate the "kicked-out" sump, but I'm sure I can piece together a decent windage screen, trapdoor, and baffle set for my stock pan.
Couldn't I just make a windage tray with some steel screening and some long hinges(?) folded over and bolted together? Also, in the case of trap-doors, what is the best design?
I might be in a little over my head, so just tell me if I am...
Old Feb 10, 2004 | 04:01 AM
MaxRaceSoftware's Avatar
if you like doing things yourself ..go after it !
but it will be cheaper in long run to go buy a pan such as Moroso with swinging/hinged trap door at sump
at very least ..go visit your local speed shop or look at online catalogues at inside pics of oil pans
one more thing to watch out for ...is having enough experience in knowing how much metal stress you will cause into pan with welding
how and where your finished oil pan might shift under heat
and crank windage, and car motion with oil weight in pan
HectorM52
Jul 30, 2017 11:46 AM
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
