"o-ringing"
Old Nov 16, 2002 | 05:20 PM
MEATHEAD's Avatar
"o-ringing"
I'm at a point in a project where I need to decide between o-ringing the block or the aluminum heads. What do you guys think would be the better choice, and why?
Thanks in advance,
Shannon
Old Nov 16, 2002 | 07:25 PM
KTamez's Avatar
My Block is O-Ringed without grooves in the heads. This allows me to Repair/Mill/Swap Cylinder heads in the future w/o worrying about matching up the grooves to Rings in the block.
Good luck!
Old Nov 17, 2002 | 11:42 AM
Thomash's Avatar
I was running an O-ringed block with no grooves in the heads. Worked OK until I got my compression over 14:1 then I had sealing problems. When I groved the heads the problem went away.
