NOS ? since I converted to a single plain
Old Mar 23, 2005 | 04:24 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Could I run a plate setup like you see on the carbed motors. I would think I could just jet it like a efi setup. I don't feel like pluming for direct port but if that's my only options know then so be it. Wasn't sure if I needed to put this in the NOS forum, so I'm asking here, since I did a conversion to a single plain intake.
Neal
Old Mar 23, 2005 | 05:22 PM
captaindbol's Avatar
Re: NOS ? since I converted to a single plain
It might work great but I don't know of one single plate system made for high pressure. I would use the plate but plumb in a bypass regulator and run the plate at carb pressures(6-10psi). Thats just my two cents worth.
Old Mar 23, 2005 | 05:29 PM
SStrokerAce's Avatar
Sounds like a good idea...
Captaindbol where the hell did you come from anyways? Lots of good posts lately.
PNYKILR, you talking about a 23 or 18 deg head setup here right?
Bret
Old Mar 23, 2005 | 05:59 PM
PNYKILR's Avatar
Bret
It's still a 23* head(AFR 210's). Since I can't run a single fogger nozzle on this thing any more I wanted to run a plate on top of the Victor Jr EFI intake that's on it now. I only want to spray a 175 shot through it. Nothing too big. Just wondering if a plate setup would work since i'm still EFI? Wonder what jetting I would need. I was going to run a small 1 gallon fuel cell up front for the fuel portion, so I would guess I could run a small fuel pump and reg it to 10psi. This would be new to me so I don't really know how it needs to be setup?
Neal
Old Mar 23, 2005 | 06:31 PM
Hot Rod Hawk's Avatar
Well if your gonna run a low pressure fuel system I'd say give the 6.5 PSI route a try with whats called the "square tune" it works well with a NOS double cross plate system. You run the same size jet for nitrous and fuel. 850 for bottle pressure also. So if your looking for 175 hp go with 68's for jets.
Old Mar 23, 2005 | 06:55 PM
Dave69Z's Avatar
How good a plate is the NOS Double Cross Bar system in the 300-350 range? Is there a better setup for the money? With the Super Victor I will be running and the extended runners into the plenum I understand that it is more recommended to run than say a Big Shot Plate system.
Dave
Old Mar 23, 2005 | 07:21 PM
A double cross is good for 500 hp easy. It's a proven winner on track and is like running fogger power but in a plate and as you mentioned it is great with manifolds with runners that extend into the plenum. The only plate I'd run on a SBC single plane.
Old Mar 26, 2005 | 01:12 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
so pick up a holley black pump, and a regulator plumb it and spray it
Old Mar 26, 2005 | 01:20 PM
Dam right Taner
...and hang on
Potent77
Mar 16, 2022 12:13 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Elcojoe
Nov 17, 2014 10:27 PM
