The new vortec head design
Old Jul 8, 2004 | 02:54 PM
12Second3rdgen's Avatar
Any of you smart guys get to see these yet or see flow #'s yet?
Large Port Bare Vortec Bow-tie Cylinder Head # 25534371
PRICE: $332.53
GM Performance Parts latest most powerful iron cylinder head with "large ports" for Street or Racing.
This Vortec design Special Performance cast iron cylinder head features revised intake and exhaust ports and machined for 2.00" intake valve and 1.55" exhaust valves. The deck surface is .450" with 65 cc combustion chambers, 206 cc intake and 77 cc exhaust ports.
All Vortec intake ports are taller and narrower than early model Chevrolet heads.
The valve cover mounting holes are for both early model flange or late model center. This head also includes intake manifold mounting holes for both early model 6 bolt main or late model 4 bolt Vortec design.
The head is machined for 3/8" screw in rocker studs, large valve spring pocket machining and will accept up to .530" lift camshafts with out modifications. Heads are identified with the Bow-Tie logo on the exterior of the head below exhaust flange and Vortec logo on top of intake port area.
They also feature GM logo cast into bottom of intake ports.
Technical Note:
You must use a raised runner design intake manifold P/N 10051103 (6 bolt mounting), or Vortec design 12366573, 12496820, 12496821, 12496822, and 12499371 (4 bolt mounting) with this head.
You can use production Vortec intake gaskets P/N 12529094 (torque spec. 11ftlb/ 15Nm) for mounting Vortec design heads or use P/N 12497760 (torque spec. 30 ft-lb) with conventional material when using on early model raised runner or Vortec design intake manifolds, this gasket has both 6 bolt and 4 bolt Vortec attaching holes.
Head casting P/N 25534371C.
Old Jul 8, 2004 | 11:05 PM
AutoRoc's Avatar
An iron casted fastburn head possibly? Dimensions sound similar!
NewsBot
Mar 1, 2015 09:55 AM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
CARiD
Dec 26, 2014 04:20 AM
