New Comp 26120 Beehive spring. It's a biggun
Old Nov 17, 2004 | 08:30 PM
Spinner's Avatar
part # 26120
1.095/1.445 OD
1.00/.650 ID
155lb @ 1.88
377lb @ 1.28
Coil bind at 1.23
370 lb/in rate
These are bigguns, bigger then the 918s, finally there is another alternative in the beehive category for those applications needing something a little stronger then the 918s. Is there any good way to adapt these to an LT/LS head?
Old Nov 17, 2004 | 09:17 PM
SStrokerAce's Avatar
Re: New Comp 26120 Beehive spring. It's a biggun
Not really a new spring, been out there for BBC Hyd Roller setups for a long time.
Run them on a few motors already. They work really well on marine BBC's using Hyd Rollers, and street BBC Hyd Roller motors.
They WILL NOT bolt up to stock LT1 or LS1 heads, so don't try. You have to change the whole system to get them to work.
They also have more mass than a 918, it's not just about spring pressure but mass and spring pressure.
Bret
Old Nov 18, 2004 | 12:31 AM
Spinner's Avatar
Was hard to tell, just noticed them in the 2004 comp new products listing and there weren't too too many details there.
Old Nov 20, 2004 | 04:17 PM
94 TA TT2S's Avatar
Yeah they can be made to work with LT1 heads though......As Bret Said.....
Old Nov 23, 2004 | 12:37 AM
How do you know? ;-)
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
