Need some help here, converting to single plane intake
From: Albuquerque,NM--5,600 feet above you sea-level cats
This is the one I'm ordering/Edelbrock 29785 w/3630 (Fuel Rails)
http://www.advancedperformance-efi.com/intakes.php
I also want to plug a distributor in the back with a crank trigger. What I want to know is what distrubutor will work under the dash? Do I still need the opti? What do I use as the control modual? What about a ballancer? Basically what do I need to make this work?
Go here for the throttle Body. I will be running the 2000 cfm one.
http://www.force-efi.com/parts.htm
Neal
Neal
Also, Since I wont be running the opti any more, do I even need the fast system with opti, or can I just order a regular fast setup for a chevy SB?
Neal
Neal
Re: Need some help here, converting to single plane intake
Neal
Neal
Im doing something similiar.
Going to run the Crab cap as bret mentioned. Cheap as its basically just a cap and rotor with no vacuum advance etc features. (155 bucks)
Pull out the opti rotor, and run the coil wire to the crab cap.
That will leave the stock ECM in charge of timing, using the opti high and low res pulse still functional in the back of the opti on the optical wheel itsellf. That virtually eliminates all opti falures (flung apart rotors, and corrosion) and will just use it as a crank sensor to feed the hi/low resolution pulses to the ecm.
Also, check your PMs. Ive got something you may be interested in.
Re: Re: Need some help here, converting to single plane intake
Originally posted by The Big Show
Good luck with that. I waited two months and got nothing but empty promises from Rob. Towards the end of my wait I started to receive lies as well.
Re: Re: Re: Need some help here, converting to single plane intake
Originally posted by kmook
I talked to him before and he seemed real nice, though anyone trying to make $ should be nice. You should have told me and i'd have drove down and picked it up in person.
And I'm posting all this for the original poster to see so he can know who he's dealing with. Not hijacking your thread at all.
Well I don't want to have this problem at all. Where else can I get this type of Throttle Body?
I might take you up on that, if your close buy him. Aslong as its in stock there at his shop I don't think there will be a problem.
Neal
Neal
I dunno. Thats the only place I found that sold a throttlebody that big. Thing is most street/strip cars (heads) don't even make use of that much tb.
About the crab cap distributor. If you run your coil wire from to the distributor and still use the opti for the computer, what do you do with the wires that come out of the distributor for the crank magnet? Do you just leave that alone or what?
There is a throttle body that big on Wilson's Manifolds for $721.
