Need ABS conversion help on my 95 TA!
Ok I'm going with a Ford 9" rear end & you can use ABS if you have the 4 channel system, now I have a spare 97 rear end with the 4 channel abs that has the abs gears on the sides instead of inside the differential, now my question is, can I make my 95 Trans AM which uses the 3 channel abs converted to the 4 channel abs? I have the reluctor gears & everything on the rear end part, what else needs to be change to do the swap? thanx guys
I think to go from 3 channel (no TCS) to 4 channel would be a lot of work. You would needed a different ABS unit up front and you would have to run another brake line to the rear, you need one for each wheel. I am fairly sure the 4 channel cars have it set up that way. There are probably more things you would have to change. Or, you can just make you 3 channel ABS work with the 9 inch. I did it to mine and has been working just like it did with the 10-bolt for around 2 years now. Send me an e-mail and I will send you the details and some pics.
RUENUF
Mar 13, 2016 03:37 PM
tdigger9899
Sep 7, 2015 10:56 AM
