major clutch problem
i have a v6 camaro.. its a 5 speed.. but i figured you guys could help me out as well.
ok.. its kind of hard to explain. ill do my best.
lately my clutch has been feeling weird.
it grips at a different point all the time.
this morning when i started up my car, i pressed the clutch in, tried to put it in 5th then to revers.. but it wouldnt go in 5th. no matter how hard i tried..
the clutch was pressed in alll the way..
then after a while it went back to normal. i drove it to the bank to deposit a check. went back in the car. same thing. car started up when the clutch was pressed in.. now it wont go in gear... i actually got it in reverse.. but i tried to get out of reverse to head home.. but it wouldnt get out of revers.. i had to YANK IT out of revers before i backed into another car. WHY IS IT DOING THIS?
is there some fluid that could be low? ehhh..
its a 5speed. the actual clutch does not slip what so ever. could it be the throw out bearing?
its really weird.
now im stuck hikeing 5 miles to get to work today. ehhh
any help would be greatly appreciated
its really weird.
Advanced Tech
Advanced tech discussion for all years. Stroker motors, Driveline rebuilds, etc... HIGH-END DISCUSSION ONLY - NOT FOR GENERAL TECH INFO
maybe YOUR the idiot.. because this is driveline related... AND there is no general tech.. or DRIVETRAIN section
so.. in that case.. think before you speak.. or just dont post if your not willing to help.
oh..and YOU, have a pleasant day
~Tyler
~Tyler
This may be about a drivetrain, but it is a routine maintenance problem that would best be handled in "V6 Tech", since the people there deal with this kind of problem every day.
There is no need for the nasty response to your post, and there is need need for your "in-kind" response.
This post will be locked. Please don't either of you let this happen again.
Fred
Fred
