LT1 v/s Gen1 Cam Specs?
Old Jun 2, 2004 | 02:45 PM
Bone Daddy's Avatar
Im sure this is in the correct section, if not please feel free to move, and my apologies.
Odd question...
What are the differences between a Gen1 cam versus a LT1 cam? I know the LT1 cam has a "protrusion" on the end for the opti, but are the lobes shaped the same? Are the main lobe's the same diameter?
Could an lt1 cam be ground in front (removes the protrsuion) and be compatable in a Gen1 block?
Thanks,
-Bone-
Old Jun 2, 2004 | 02:53 PM
AdioSS's Avatar
West South Central Moderator
You can put a Gen 1 cam in an LT1 fairly easily and you can put an LT1 cam in a Gen 1 very easily
Old Jun 2, 2004 | 03:01 PM
Bone Daddy's Avatar
So the only difference is that the LT1 cam has that "****" on the end? Do you know anybody on the board running a Gen1 SBC camshaft in their LT1?
[edit] would I have to run different lifters/pushrods/ etc.?
Old Jun 2, 2004 | 03:51 PM
Mindgame's Avatar
Bone Daddy,
What exactly are you trying to do here?
If you happen across a cam in a catalog that is not listed as an "LT1" cam and want to use it, just call the cam company and they can grind the cam with the necessary step nose and dowel hole. I'm guessing about your intent though....
Let us know.
-Mindgame
Old Jun 2, 2004 | 05:51 PM
Bone Daddy's Avatar
No "intent" really, just thinking of doing something and I don't have the two cams to compare.
Just wanted to know in general what the differences between the two were.. I'm assuming that the LT1 nose groove and the longer dowl pin (for the opti) are the only difference?
Old Jun 2, 2004 | 07:11 PM
Mindgame's Avatar
Yes, to my knowledge those are the only differences.
Good luck.
-Mindgame
Old Jun 2, 2004 | 08:00 PM
Bone Daddy's Avatar
Thanks X 2, Mindgame.
Old Jan 17, 2009 | 09:25 PM
Bersaglieri's Avatar
My buddy and I were talking about this today, something like a thrust bearing kit for the front right? I know Mindgame was talking about having the cam custom tailored, but what if you want to be able to swap cams with your SBC in your Nova or Chevelle? I have a few friends who have ALOT of SBC cams lying around that I could use.
-Dustin-
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Queens94z28
Nov 20, 2014 06:03 PM
