LT1 396 using a 6 inch rod and direct port nitrous?
Old Sep 24, 2004 | 01:15 PM
  #16
OldSStroker's Avatar
Re: LT1 396 using a 6 inch rod and direct port nitrous?
Originally Posted by rskrause
Yep, the math is right. GM picked a 3.80" crank for the crate stroker because it allowed them to use existing pistons.
Rich
My take is that it allowed the same 4.00 bore so the blocks could be machined on standard production equipment. For an OEM, running a special bore size is expensive, as are special length rods, but a special CH piston is relatively cheap to insert into regular production, or even buy outside.
As long as the crank was special, the 3.80 gives a 382 (close enough!) vs. 377 from a 3.75.
I believe the crate 383 has standard 5.7 rods.
My $.02
Old Sep 24, 2004 | 01:37 PM
  #17
Mindgame's Avatar
Thumbs up Re: LT1 396 using a 6 inch rod and direct port nitrous?
Originally Posted by Injuneer
The shop that built my engine tends to be extremely conservative, favoring reliability over squeezing the last ounce of HP out of an engine. Knowing I was going to spray a 300-shot, they recommended a 5.85" rod, even on a 3.75" stroke. They also followed that approach with George Baxter's LT1 engine, which ultimately survived and proved extremely reliable at the 1,100+HP level, running 20# of boost. His 383 engine actually started out life with 5.7" rods, but they were replaced with the 5.85" Oliver Billets, when the previous Oliver forged rods started to shown signs of stress.
I'm following ya Fred. That's the route I'd go and that's what I'd recommend as well. Just surprised to see so many guy going with the shorter comp height. There isn't really much to gain (if anything). I'd opt for moving the top ring further from the combustion chamber and the 5.85 gives you that little bit of added security.
-Mindgame
Old Oct 1, 2004 | 09:22 AM
  #18
SLED28's Avatar
I've personaly run a 400+ shot on a 6" rod 396 setup. It was a 1.06 comp height. It went 9.11@155mph at 3400lbs. I have built both combinations, 5.85 or 6" and they both work, but I would suggest using a 5.85 rod. Email me if you need anything.
Dave
GMPerf
oldschool
Feb 9, 2016 09:21 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Jul 4, 2005 05:00 PM
