LT1 367 any advnatages and or disadvantages?
Nope no type-o, check out the link, they already make a version for the conventional SBC, and one for the late-model GEN 1 87-up blocks. Are the LT-1 crankshaft different than the regular 87-up 1-piece RMS cranks? If so what is the difference, I would like to know please
"LT-1 CHEVY 350 TO 363 CID STEROKER CRANK KIT"
Boy, can't wait to get one of them steroker 363s...
Do you have any idea how ridiculous building a "363" is? It makes no sense whatsoever.
ACTUALLY Jim it makes ALOT of sence for some people. You being in the hart of Auto_X country and all I just figured you would know the rules
I got a feeling 363 is legal for a 6.0L limit class(Street Mod comes to mind) and 383(6.2L) is not
If I were building a motor that was limited to 6.0L, I'd use a 400 style block with a shorter stroke
4.155" bore + 3.375" stroke = 5999.25cc
or if one of the newer Motowon blocks were available
4.25" bore + offset ground 327 crank (3.226" stroke) = 5999.58cc
Should be able to fit some big *** valves in there to move LOTS of air
Originally posted by jimlab
I've never had anything against traffic cones, so I've never felt the need to go run over some in a big parking lot...
Ellis,
Your "feeling" is dead on, 6.0L is the max allowable displacement for a pushrod V8 engine in SM.
Jason
Dodging traffic cones (poorly) since '00
Originally posted by Soma07
If you're running them over then you're doing it all wrong
I "autocrossed" when I was much younger, but it involved half ton vans and shopping carts...
363 is not a typo. They use a 3.563" stroke and a 4.030" bore. But it is an oddball combo.
If you're building to a 6.0L (366 cid) limit, why not go with commonly available parts? Like 4.060" bore and a 3.500" stroke. Or better yet, a 4.165" bore and a 3.300" stroke.
And if you're not trying to meet class-rules, why would you spend any money just to gain 13 cubes?
I am suprised Bret did not mention most newer SBC motors become unstable at 4.060 bore. This is a extended high RPM sport. Last time I went tach never dropped under 4,500 the entire run and was over 6,000 for most of it. noit long say 1.30 Minutes
I believe After market blocks are not allowed nore are other then stock castings.
I was just trying to point out why they would do it.
One day I hope to see jimlabs car move
Hey I drive Ricers in AutoX so I can't talk, but still put up a good amount of 1st places when someone gives me a ride.
Bret
