Jesel mounted rocker arms
Old Aug 17, 2002 | 12:11 PM
chevy94c's Avatar
Question Jesel mounted rocker arms
I am going to be ordering AFR 190cc LT1 Heads do i just get the ones for the SBC or? Who sells these rockers?
Vigilante 3200 Stall Converter, LS1 Driveshaft, B&M Supercooler 19,000 GVW, Moroso Cold Air Induction, MAF Translator Plus, LT4 KM, Fan Switch, Jet IAT, Hypertech Power Stat, MSD Coil, NGK TR6 Plugs, Jacobs Wires, Russell Wire Dividers, Scanmaster, 3.23 Gears, SLP Headers w/PBM Coating, Borla Adj Catback, DMH E-Borla, Air Foil, Metco Breather, LT4 Starter, NX System, Nitto drag radials, Hal rear shocks, BMR STB PHR LCA
Old Aug 17, 2002 | 12:43 PM
Stephen 87 IROC's Avatar
Post
Jesel rockers are nice but will probably cost close to what the heads cost.
Jegs and Summit sell Jesel rocker arms.
Get heads for regular rockers.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.418
Best MPH on a time slip: 117.01
Best corrected ET: 11.051
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.595
Member of the Calgary Drag Racing Association
Old Aug 17, 2002 | 03:03 PM
kmook's Avatar
Advanced Tech Moderator
Post
I bought mine directly from Jesel www.jesel.com
Be prepared to spend about $700 or $1200 depending on the series you want.
I bought the $700 ones and ended up not using them because they would not fit. Personally jesel's customer service was getting really annoying becauase they kept telling me oh we know they work with your setup, yet they clearly did not clear the springs/retainers....
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
[This message has been edited by kmook (edited August 17, 2002).]
Old Aug 17, 2002 | 04:05 PM
AdioSS's Avatar
West South Central Moderator
Thumbs up
chevy94c, you've got mail
Cheston P - IM_A_0@yahoo.com AIM:Impalaitis
96 BBB Impala SS "ADIOSS"
91 white Caprice 'n0n 9c1' w/L03
GM_TBI listserv
GMForums.com
ImpalaSSForum.com
Old Aug 21, 2002 | 10:43 AM
sleeperz28's Avatar
Post
You might have to get your heads machined to make the shafts fit. I would look into crower shaftrockers. I put them on my car and they are very quiet, stainless steal, lighter and not as bulky as the aluminum jesel. I would call Jesel about the machining. Crower uses spacers to eliminate the need for machining the heads.
Just something to think about
1994 Turbocharged Camaro
Old Aug 21, 2002 | 04:47 PM
chevy94c's Avatar
Post
Thanks sleeper
69z-28
Jan 29, 2016 10:46 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
KamikaZ28
May 28, 2015 12:45 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
