Intake Runner Length
Re: Intake Runner Length
Originally Posted by crash4cyl
even still the big difference is the huge variation in durations....usually they're somewhat close to each other....I'll get IVO,IVC,EVO,EVC #'s for you tomorrow...Gotta go home and play on the computer, the only problem is that no-one has a centerline #...That would probably change it around a bit...
Chris
Chris
Bret
Part of the problem you guys are running into with the backpressure and manifold pressures of turbo setups is the way you're looking at it. It isn't a static case, it's a dynamic case. You just can't "pause" time and look at how the pressures relate to each other. You just can't say the pressure in the exhaust is "this" and the intake manifold pressure is "that" at "whatever" time, and conclude that the exhaust gasses will automatically revert into the chamber. A gas is a fluid, and fluids have the properties of mass and momentum. And for this reason, overlap is beneficial *to a point* on turbo setups. A particular turbo setup might be making 10psi of boost, with 15-17psi of backpressure at some high rpm. But some overlap doesn't mean that you'll get reversion. When the piston pushes with exhaust gases out of the cylinder during the period before the intake valve opens, they build momentum and "push" against the backpressure in the exhaust. And at an infentesimal amount of time there is no "backpressure" pushing the gases back into the port since the momentum of the exiting exhaust is canceling the forces of the backpressure and leaves a near pressureless area. Thus, when the fresh charge (at a lower psi) is being forced into the cylinder during this time you get the "sweeping" effect in the chamber you hear about. Even though there is more pressure in the exhaust, momentum gives the intake charge an opportunity to enter the cylinder for a small amount of time.
This kinda resembles ram tuning in reverse... remember that in NA setups you can still get more air into the chamber via the intake port even if the pressure in the cylinder is higher then the port due to the momentum of the entering gases pushing more into the cylinder until the valve closes ( i realize that this only occurs to a point... and you want the intake valve to close just at the point of reversion into the port). It's applicable to turbos too. You want this sweeping effect only to the point where the exhaust gases begin to reverse direction and push back into the chamber. You want this to be imminent when the exhaust valve closes to help force that little bit more exhaust out of the cylinder. You have a more "pure" intake charge than if there was no sweeping effect due to having no overlap.
There are also limits to this. The optimum point of most efficiency occurs only in a certain range of rpm and boost. And you have to make compromises. You must try to limit your time in the areas of least efficiency and make most of your run time in the areas of highest efficiency as possible. Whether you do this with stall converters, higher gears, ect. is up to you and how you race (dragstrip, autocross, etc). And as to just how much of a difference these effects make... who knows, too many variables to consider. But you can be rest assured that the most effecient turbo cams out there do have some overlap tailored to what their application is.
I don't mean to pick apart your post, but I'd like to clarify your wording.
>>"A gas is a fluid"?
Please elaborate.
>>"A particular turbo setup might be making 10psi of boost, with 15-17psi of
>>get reversion."
From your post I can't quite gather if you are stating that:
reversion occurs after a point of engine RPM where intake pressure is constantly higher than exhaust pressure
or
reversion only occurs at points where the momentum of flow is not able
to overcome reflected pulses and atmospheric pressure.
Lastly,
>>"you can still get more air into the chamber via the intake port even if the
>>the entering gases pushing more into the cylinder "
If the charge always moves from a high pressure area toward a lower
pressure area (trying to equalize), then it's safe to state that a higher pressure
in the clyinder will not allow a lower pressure from the intake port to enter.
An object of a certain mass that has momentum, also contains 'x' amount
of energy, or force.
If this forward moving mass (intake charge) has enough force to overcome a given pressure in the cylinder, can we not conclude that the forward moving
intake charge has a higher pressure than the cylinder?
IOW: veloicty of the gas is proportional to the pressure. The intake charge
will not enter the cylinder if the cylinder pressure is higher than the intake
port pressure.
The intake valve can hang open longer (IVC) and charge will continue to enter
the cylinder until the piston creates a higher pressure when reversing ABDC.
The amount of extra filling will vary and depends on the momentum and force of intake
charge which is dynamic throughout RPM.
>>"A gas is a fluid"?
Please elaborate.
>>get reversion."
or
Lastly,
port pressure.
Originally Posted by Zero_to_69
"The problem is that "brick" is what's supplying your intake with boost"
Now we're getting into a totally seperate subject .
My initial statement in response to the previous post simply meant, if the
exhaust is backed up due to restriction, the charge isn't entering the cylinder.
In order to increase cylinder filling, the exhaust flow must be free flowing.
The potential difference in pressure between the exhaust runner and
plenum = manifold pressure; or a closed intake valve and the plenum (depending
on the point in time in which you sample).
25 pounds of manifold boost means nothing if it's not getting into the cylinder.
The S/C is simply pressurizing the plenum at a higher rate than the pistons
can draw from the plenum.
If the pressure behind the intake valve is sitting at 15 PSI, the charge will
rush in proportional to the lower pressure created by the piston drawing down
on the intake stroke.
At the point the intake valve begins to open, the piston isn't moving much,
that is why some overlap coupled with a fast moving exhaust pulse down the
header primary will help lower the pressure within the chamber and help suck in
more intake charge. This will also push out any residual exhaust gas which
would otherwise displace the fresh charge.
I checked out the LS1-GT7 cam. It seems fairly standard other than the LSA.
There's no sign of valve timing anywhere!
Someone find these IVO, EVC specs and post them!
..................Intake........Exhaust
Lobe lift:......0.326”........0.321”
Rocker ratio:..1.7:1........1.7:1
Valve lift:.....0.554”........0.546”
Duration at 0.050: 208/ 230
Advertised (total) duration:" 261/ 282
Lobe separation angle: 121.0
Centerline:
Centerline:
isn't it to the power of (1/2) with some constant? Massflow anyway
I don't consider proportional to mean linear by any stretch.
From the quote you underlined, I do believe that a piston which accelerates
faster from TDC to BDC will create a lower pressure region in the cylinder
causing more air to enter. Couple that with a pressurized charge and the
VE% increases dramatically.
Also keeping in mind, the piston speed is not constant through the crank roation, nor is it constant as the engine winds up under acceleration (due to
dynamic engine load ).
If the mass/density of the charge is not constant, inertia will play a big role
in how much charge enters the cylinder I would imagine.
The torque plot of an engine is likely the best indication of when all of the pieces
are working to their best potential over a range of RPM.
I'm quoting most of this from a text, and trying to apply it to the best of my
ability. Obviously, most of us here don't have the test facilities to actually
gauge, or study these flow characteristics, so please correct me where I'm wrong.
From the quote you underlined, I do believe that a piston which accelerates faster from TDC to BDC will create a lower pressure region in the cylinder causing more air to enter. Couple that with a pressurized charge and the VE% increases dramatically.
Keeping in mind, the piston speed is not constant through the crank roation, nor is it constant as the engine winds up under acceleration (due to dynamic engine load ).
If the mass/density of the charge is not constant, inertia will play a big role in how much charge enters the cylinder I would imagine.
The torque plot of an engine is likely the best indication of when all of the pieces are working to their best potential over a range of RPM.
I'm quoting most of this from a text, and trying to apply it to the best of my ability. Obviously, most of us here don't have the test facilities to actually gauge, or study these flow characteristics, so please correct me where I'm wrong.
getting off topic, but isn't proportional implying a scale of some sort- such as 3 or 4x bigger?
like when you say "their head is improportional to their body" or something.
3 entries found for proportional.
pro·por·tion·al ( P ) Pronunciation Key (pr-pôrsh-nl, -pr-)
adj.
Forming a relationship with other parts or quantities; being in proportion.
Properly related in size, degree, or other measurable characteristics; corresponding: Punishment ought to be proportional to the crime.
Mathematics. Having the same or a constant ratio.
I guess I can be a non-linear function, but i never took it that way. carry on!
adj.
>>"A gas is a fluid"?
Please elaborate.
http://www.hyperdictionary.com/dictionary/fluid
http://www.efunda.com/formulae/fluids/overview.cfm
>>"A particular turbo setup might be making 10psi of boost, with 15-17psi of backpressure at some high rpm. But some overlap doesn't mean that you'll get reversion."
or
or
Lastly,
If this forward moving mass (intake charge) has enough force to overcome a given pressure in the cylinder, can we not conclude that the forward moving intake charge has a higher pressure than the cylinder?
port pressure.
port pressure.
I'm still a little rusty on this stuff as i'm still learning it, so any critique will be well taken.
Originally Posted by stonebreaker
Vizard's cam amd valvetrain book
He gives some interesting specs for a turbo cam that he ran in a 1000 hp, 1100 tq motor:
200/235 duration, 126 LSA, installed 9 degrees retarded. This closes the exhaust right at TDC and doesn't open the intake until 35 deg after TDC, because up until then the pressure in the cylinder is greater than the amount of boost in the intake.
Anyway , does anyone know the name of the book , and / or any more books with info from Vizard about turbo cams?
Fast Caddie,
Nice response.
You are confusing me however as I'm sure my posts indicate dynamic pressure
changes.
"Again, you are not dealing with a static case (no momentum in the system of moving parts/particles). You are dealing with fluids and their dynamic properties."
As long as the pistons and valves are moving, there is change in pressure
thoughtout the system.
When I'm speaking, I am refering to a moment in time...at least that is what
I hope to be portraying. Freezing, or taking a snap shot of pressure values
at different points in the engine.
IE: When the piston is at 5 degrees ATDC, the pressure at the intake valve
may be ~ 3 PSI; - 2 PSI in the chamber; -4 PSI at the exhaust port.
Again, much of this has been hashed from the text, "Scientific Design of
Exhaust and Intake Systems" and "Automotive Mechanics and Technology".
From the above scenario at that moment in time, intake charge will fill the
cylinder to a certain degree.
As the piston draws down futher (continues to accelerate) and creates even
lower pressure, there must be a further amount of intake charge to fill the 'void'.
I can appreciate that there are reflected waves, and at that very point in time
at the intake valve, there may be a pressure wave which has bounced off
the valve and heading toward the plenum, but there must be some amount
of forward moving pressure that can fill the low pressure area in the cylinder.
If there was a method to model the engine using eight syringes (as pistons and cylinders) and water (as charge), it may show us a weak representation
of how waves bounce around and the syringes fill up with water at different
rates over RPM.
I know we can't equate the flow properties of water with air, but I'm sure
using a visual such as water, and our imaginations, we would observe that
only a certain range of RPM would allow 100% (possibly > 100%) filling of
the syringe, and the less efficient RPM range would show a loss of water
in the syringe.
It would also be cool to see the waves crashing back and forth against the
valve changing their 'wavelength' as RPM changes and looking for that
initial relflection to be 'in phase' just as the intake valve opens so that the
water can force itself into the syringe.
Nice response.
changes.
rates over RPM.
in the syringe.
I think we're on the same page as far as the moment in time, or "snapshot" while these events are occuring. The only point i'm trying to get across is that even with this snapshot, strickly looking at the pressure differences doesn't give you an accurate depiction of how the air is moving. It could be moving in one direction, but it could be in a transition period where it's decelerating and hasn't yet begun to move in the direction of lower pressure. All the particles have to decelerate in one direction, stop, and then accelerate in the other direction... which is what i meant by the transition period. Like the Old one said, there are lags in the system. Lags to accelerate and begin moving, lags to stop, and lags to respond to pressure differences(like more air entering the cylinder through the intake port even though the pressure in the cylinder might be higher than the port.. where reversion is imminent).
Using water in a slow speed system might give an idea of what's going on, but then again, water isn't classified as "compressible" like air is. Combined with the fact that since water molecules are much closer together, meaning their intermolecular forces are stronger, it won't give an absolute strategy to model air flow in a high speed system where water could almost act like sand or cement. That's why there have been MANY methods developed and years spent trying to test the theories behind all this air movement through an engine... it's utterly hard to make an exact model. Or even get cold, hard data to make precise emperical equations to give exact representative calculations. Hell, even trying to understand all this theory can be more than enough to make you pull you hair out. I'm half bald already like it is. lol
Originally Posted by SStrokerAce
No you are right on all of those effects............
The problem is with centrifigal blowers low rpm TQ can suffer if you stick with late IVC and since you are usually dealing with low compression levels there is only so much you can do. So if you make the IVC earlier (raising DCR) and you want to put some duration in there you are going to have overlap, no way to get around it.
I don't shy away from duration on blower cams, for the most part big blower cams are 224/236 range, which in the case of a blown SBC, especially with extra cubes is not always enough. The more duration you get with valve events in the right area is going to cause you to get overlap.
Turbo cams are interesting also since you do have other things to deal with that you don't with a centrifgal blower, one of the big things is exhaust backpressure another is turbo spool up and how fast the boost comes in compared to a centrifigal blower. A turbo doesn't have a linear boost curve if it's done right it comes on early and hangs there for as long as possible.
The backpressure is interesting and it's not a bad idea to have more boost on the intake side than you have backpressure on the exhaust side.
As for that LPE cam, it's not a bad idea I like where they are going with that vs. the standard thinking in turbo cams.
Remember LSA, advance and duration are just numbers if you get caught in a range then you are not going to find new avenues to find power. You have to give the motor what it wants not what you think it wants.
Bret
Bret
excessive intake and overlap durration are never negligable. AAMOF, nothing is IMO. But thats just me, and race industry in general. It may be negligable on the street, but it can be done correctly, why not?
Originally Posted by Boost It!
I guess we just disagree. I am not of the mentality that bigger is better with (any) blower cams.
I guess excessive overlap to me is different from you. When we are talking about 30-40-50 degs of overlap that's excessive, blower cams on street cars never see that much, but -5, -10, 0 overlap I don't think is the right way to go either.
Bret
Thanks for the reply once again Fast Caddie.
I see where the confusion lays. Reciprocating pulse/air waves in the runnners would certainly have a tough
time changing direction and gathering new momentum.
On another note:
Has anybody sourced the valve timing for the LS1-GT7 camshaft?
I can't find it anywhere. Must be top secret
On another note:
