Intake Fabrication?
Intake Fabrication?
OK I have recently gotten into fabricating my own stuff. I have the privlage of workign with a machinist/tool and die maker in the army right now.
My question has to do with intake manifold design. I want to make my own but I dont know what calculations to use to figure out Runner Length or Plenum volume. What calcualtions could I use to figure out what woudl be optimum for my application?
Re: Intake Fabrication?
Hi Chris,
I don't design intakes but have been around a number of people who do. I chew on their ears til they tell me what I want to know.
I look at it like this... the runner size isn't an issue because we are simply going to work from the cylinder head port and apply that same taper or something very similar. The intake runner (intake) is just an extension of the cylinder head.
Now for lengths.... how much room do you have to work with? If you keep the runners straight then chances are you're going to have something shorter than 6". Not to worry though cause from what I read in Cosmo the other day... that's about average.
On the plenum volume, I'd have to go get some of my research materials. There is some info on this over at Larry Widmer's site (TheOldOne.com) or something like that. Just search Google for it. I'll post up some more info later.
On injector angles, alot of the guys I've talked too don't feel they're that important. Then there are those who do.
If you look at Mike Moran and some of those other guys you'll see that whoever built their intakes wasn't too concerned with it either. Even the LS6 head has a little worse targeting than the LS1, but they felt that the port was more important than the targeting. It's an open debate for sure. Then again, some injectors have wider spray patterns than others...
On building.... I'd look at what Kinsler does with theirs and make a valley cover. Just makes things easier to work on when you're in there taking things apart.
Just a few thoughts.
edit: This may help you out.
http://www.theoldone.com/archive/
-Mindgame
-Mindgame
I know nothing about this but found this site. might help might be not.
http://snow.prohosting.com/~johngift/intakefab.html
People will build things but man... some of them sure are ugly.
edit: Oh... that really threw me bad. Meant to ask a question.
Is this intake for FI or is it going to be carbureted? The plenum volume for carbureted is much more critical than that for FI.
-Mindgame
Not only does that intake probably weigh 50-60 lbs., but did you see the hole he cut in his firewall to clear the back of the plenum? Nice.
http://snow.prohosting.com/~johngift/On1.jpg
I've heard/read that intake plenum volume should equal the displacement of the engine it's feeding, but I can't verify that one way or the other. Hogan's Racing did my calculations for me.
Originally Posted by streetbad
What is your application?
Also I have a Jeep Cherokee 4.0L striaght 6 that is turboed which I want to do as many custom things as possible to. Its a Typhoon/Syclone (and WRX and EVO) killer.
who would suspect the Cherokee
Oh mine wont be that heavy. I like Aluminum and have access to a CNC machine. I just have to learn how to program the thing first LOL
I have my intake harmonics chart at the bottem of the page. I have some other stuff you might want to see, If I can find it.
