Info on Unknown Cam
Old Nov 18, 2008 | 02:20 AM
TripleWhite's Avatar
Info on Unknown Cam
Here is all the info I have for it
Duration Advertised: 286* Intake/307* Exhaust
Duration @.050: 230* Intake 245* Exhaust
Lift with 1.5:1 rocker arms .565 Intake/.600 Exhaust
LSA:114
Has the long dowel pin for 95-97 lt1s
Its a comp, custom ground, if any of you board member recognize the specs of the cam and have any info, ie whos grind it is or if its just an off one.
Any input of what the cam would sould like or how aggressive, any videos of similar cams, etc.
Thanks to all members
Old Nov 18, 2008 | 01:38 PM
camarobird92's Avatar
That is a strange cam... I've never seen one with a .050 duration split that far. It's a lot of intake lift for a short duration too.
Have you tried calling or e-mailing Comp?
Old Nov 18, 2008 | 02:21 PM
seawolf06's Avatar
That's one messed up cam...
Old Nov 18, 2008 | 04:24 PM
AutoRoc's Avatar
Maybe he mis-typed...230/245 might be what he meant...
Nice cars you have listed! Why does the bottom car say $600? Is that the price? PM me with details.
Old Nov 18, 2008 | 08:14 PM
seawolf06's Avatar
That would make more sense.
That's probably the price he paid, haha.
Old Nov 19, 2008 | 05:51 PM
Hey guys that 203 was a typo, yes that car I got for 600
Old Nov 20, 2008 | 03:40 PM
Should be a fairly aggressive sound with a pretty big lope at idle. It should sound close to a GM847 or a CC306. It does have really high lift. Make sure and get some quality matched springs and check for piston/valve contact.
Old Dec 5, 2008 | 07:58 PM
Anyone else have a similar cam?
Old Dec 6, 2008 | 08:33 PM
AutoRoc's Avatar
CC306 is very similar as posted above..it's 230/244 and used to be very popular..Do a search on that maybe.
Old Dec 6, 2008 | 09:17 PM
96capricemgr's Avatar
Looks like an attempt at a nitrous cam judging by the split and LSA. Not saying it would be a good cam, just that it looks like someone applied some "conventional wisdom" to come up with some odd specs.
Old Dec 11, 2008 | 01:28 PM
hosspwr94's Avatar
cam specs...
Thats almost the same split as a GTP7 Cam http://gtp-racing.com/
which has int ex
236 250
.350" .372"
.560" .595"
I have a GTP 6 cam with a bit less split.
The gm 847 has a 234/242
Old Dec 12, 2008 | 03:02 AM
Do you have a video by any chance so I can get an idea of the sound also?
Old Dec 12, 2008 | 04:38 PM
Try searching on youtoube...
Old Dec 13, 2008 | 10:29 AM
hosspwr94's Avatar
you can hear my GTP6 cam on my FQuick page.
Old Dec 14, 2008 | 11:13 PM
One more question, does anyone run the GTP7 Cam and if so what hp/tq gains would I bee looking to expect as I plan to drop this in my 95 6speed. Also since Im asking what should I use when I r&r the cam/lifters/etc
Lifters-ls style?
Rocker Arms-?
RR ratio-1.5/1.52/1.6?
