hp limits on cast 383 stroker
Old Aug 31, 2002 | 07:46 PM
cadjock's Avatar
Post hp limits on cast 383 stroker
At what point will a cast piston short rod 383 self destruct? If it is related to rpm and I limit that to 5500 rpm, is there a way to increase the hp? My engine has edlebrock performer rpm heads, cam and intake with a 600 cfm dbl pump.
If the heads were ported, will I see hp improvements up to the redline, or would the redline have to increase to take advantage of the better breathing?
Old Sep 1, 2002 | 09:22 PM
Dr.Mudge's Avatar
Post
Almost any kind of heads will improve breathing for the 383 even at a meager 5500 or whatever RPM, because you need more air in/out with the more cubes that you have.
For NA cast (are they hypers or what?) pistons are ok, cast crank too I imagine? Parts should be listed with how much power they can take approximately.
Quickss96
Jan 29, 2016 05:56 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
alphaauto
Jul 26, 2015 04:40 PM
