How long should a solid roller live on the street?
Old Jun 16, 2005 | 12:31 PM
  #16
JordonMusser's Avatar
West South Central Moderator / Special Guest
Re: How long should a solid roller live on the street?
Jim- your setup sounds great, and i agree with MindGames "list".
I never had a single SR valvetrain failure.
Old Jun 16, 2005 | 04:53 PM
  #17
stealthblack's Avatar
what are the opinions as to what part idle speed plays in longevity? im a lope junkie [time it with a flashlight ] but some dude said once that a low idle will contribute to accelerated wear as the rollers arent getting that much oil so SR idle RPM shouldnt be under 1000.
I figure if youve got decent oil pressure at 650 or 1200, whats the difference?
but to be fair the 1 street SR ive done and all my buddies SR setups, they dont get alot of street miles, and are torn down frequently anyway for upgrades/ maint.
Old Jun 17, 2005 | 02:49 AM
  #18
MaxLean's Avatar
Most are lubed by oil slung from the crank. RPM should have a role in it.
Old Jun 17, 2005 | 01:18 PM
  #19
Denny McLain's Avatar
Ya, but ya worked on a couple of mine who did fail. Again, I may have the worst luck in the world but no matter what I did I still had problems with solid lifters.
Old Jun 17, 2005 | 01:27 PM
  #20
SILVERZZ28's Avatar
Originally Posted by jimlab
Ti valves. Check!
Crower shaft rockers. Check!
Big pushrods. Check!
0.625" max lift. Check!
Crower SD lifters. Check!
174# on the seat, 430# open. Check!
Now this is one that I've pondered quite often... even with "enough" spring for the job?
That's about 4 years of driving, or more. No problem.
I totally agree. I have had two lifter failures and one rocker bearing go...
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
95chwagon
Jan 13, 2015 09:19 PM
Wicked
Jul 25, 2002 04:19 PM
Ed95Pont
Jul 23, 2002 08:26 AM
