How do I build a sheet metal intake?
I have some ideas that I want to put into play and I have a fabricator who can build anything that I can articulate, and he'll work for beer.
Thing is, I don't know if I need to start with nothing. Are there pre-made flanges I can buy?
Perhaps a valley cover with cutouts where the runners have to go so that I can have runners with a sort of "mini-flange" at the end.
For that matter, is there premade tubing that can be cut to the lengths I want, or do I need to make them from scratch?
Also, how do I calculate the proper cross-section so that I can maintain velocity without getting into too much frictional loss because I went too small?
And a plenum...
If I were to accept that I should have a plenum space roughly equal to 1/2 my engine displacement, do I count the runners as part of the plenum space or do I count only the common area?
Length tuning is another question.
Is there a reference table or rule of thumb to guide me in terms of the runner length and cross section?
What about a venturi?
I had a thought about putting a mild hourglass shape into the runners just before the intake port on the head to give the airflow a last minute "kick" into the head and "tighten up" the airflow a bit so that the main "stream" of air going into the head is trying to be "narrower" than the passage it has to move through.
Finally, for a throttle body is a "two throat" or "monoblade" design better, and why? Or does it even matter?
And a plenum...
IMO, you are in way over your head here.
No flame intended, but successful manifold design takes a great deal of knowledge of engine design. There have been a few threads about this with recommendations of books to read.
By the way, what engine you are talking about?
BTW, it's for an LT1.
I had been thinking about taking an LT1 manifold, slathering the inside with grease and doing a wax cast of the runners to see what they "look" like, but I figured it couldn't hurt to ask.
I'm really not completely ignorant of fluid dynamics, but I wanted to keep my questions simple at first, figuring that I could always complicate them later.
Well, it's for a street engine, under 7000 rpm.
I had in mind individual runners in a sort of a hockey stick shape as the approach the ports, meeting at a cylinder in the center, but drawing from something close to the opposite side.
I'm picturing a square tube coming almost straight up from the intake port, with a slight narrowing in two opposing tube walls shortly before the port, in a sort of hourglass shape.
My thought is that this narrowing would have a venturi effect, "narrowing" and accelerating the incoming air charge just before it enters the head.
Above the "hourglass", the tubing bends gently toward the longitudinal centerline of the engine, where it goes above a center tube, curving slightly around and down and drawing air from the opposite side of the tube.
So if you were standing in front of the engine and looking at a runner coming from the passenger side bank, the tube would come up, make a right turn, pass over the center tube, touching at the "12:00" position, continuing and wrapping around the tube from the 12:00 to the 2:00 or 3:00 position, with that "window" (from 12:00 - 3:00 for instance), being the opening to the tube. There would also be a widening of the runner tubing in such a way that the widest cross sectional area would be right at the point where it joined the center tube, with a gradual and smooth narrowing down to the size of the actual runner.
The center tube would be a simple aluminum cylinder, possibly 3.5" x 18", which would yield a volume of 173 cubic inches, which would be 1/2 of a 346 cubic inch engine, or about 45% of the volume of a 383cid engine.
I would mount a TB at the front end of the tube, probably a monoblade, so that the bulk of the incoming air flow can flow down the centerline of the tube, instead of towards the perimeter of the tube as it would if I used a "two-hole" TB.
In fairness, I am not giving any consideration to hood clearence, assuming that if i build this I will design it to work as well as I can and worry about modifying my hood as needed after the fact.
So the main questions that I have in mind are these:
1) Will the narrowing in the tube just above the intake port have the effect I think it will?
2) The "diameter" of the tubing is fairly easy if I just follow the lead given by the size & shape of the intake port, but the proper length is an open question.
3) How do I address the "turns" in the tubing so as to maintain flow & velocity. For instance, lets say I have 1x2 tubing and I have to make a 135 degree turn. Do I maintain the size of the tubing, or do I increase the cross section to allow the airflow to make the turn with a minimum of frictional losses?
4) Relating to #3, do I expand the cross-section of the tubing on the short side or the long side?
5) Is a center tube of 3.5" x 18" a suitable size plenum for a 383cid engine when it's only 45% of the engine's displacement?
I found the best way to do hard projects is to copy a preexciting design do a search in yahoo and take a look how other companys are making them, that way your design is down with shapes, and how the runners are formed then all yuo have to do is find out how long you need to make them, and what size plentum.
Generally you want the runner to have a constant taper of 1 or 2 or ? degrees toward the head. IMO, somewhat longer (than LT1) runners help tuning at a usable rpm. This tuning causes a positive pressure, sometimes of several psi at the inlet valve as it is closing. That's part of how VE of 100%+ is possible NA. Remember that the venturi or hourglass shape accelerates the flow which drops the pressure. That sounds like the opposite effect desired to me.
Yep, length is critical for the rpm range you are tuning. It gets back to what you want the engine to do, as aggie said. What shape torque curve do you want? what's head flow? exhaust plumbing? what trans, rear gears, tires, vehicle weight, etc? Those are the things you should consider in any engine design. The manifold is maybe the second last thing you need to specify. And the last would be....?
If you are designing a manifold from scratch, IMO, you absolutely don't want a 135 degree turn anywhere, especially in a runner which is probable in the 5 to 7 inch length. One of the reasons single plane intakes like a SuperVic works is the almost straight shot from the plenum to the port. Sure there's a 70 degree or more turn, but you can see thru the ports from above. Air struggles to turn, especially short, sharp turns. Long sweeping turns like in an LS1 intake are much better. Most dual plane manifolds have short sharp turns, but nowhere near your 135*.
As you know,air has considerable mass so when it tries to turn it's inertia wants to take it straight, so it packs up against the long side. My guess is that locally there is a more dense charge at the outside of the turn and less dense on the short side. Again, look at a SuperVic runner. It's fluid dynamics.
Depends on lots of things, IMO.
My $.02
So, sort of like a long Tulip vase then.
I would assume that the end that meets the head should be the same size as the intake port, or very slightly smaller.
I'm guessing that the very slight taper you refer to is meant to help accelerate the air as it moves toward the head. Would that be correct?
I also notice that in the calculator section there is an intake runner calculator and it refers to 2nd, 3rd & 4th harmonics.
Would you be kind enough to try to explain to me what that means in practical terms?
Also, am I totally off the wall on my venturi idea?
BTW, as to the operating range, I figure that a relatively low torque peak would serve me best. Probably somewhere in the 4000 - 4500rpm area. I am far more interested in:
a) keeping the torque curve as flat as possible, and;
b) trying to get as much area under the curve as I can mange.
In terms of the design idea, I was looking at an LS-X manifold, or rather a picture of one, and I was struck by the similarities between my concept and the LS design. It was strictly unintentional, but it is noticeable.
The reason I was looking to incorporate curves is because having curves in the runner allows me to get more length in the runner without having to go WAY above the hoodline or out over the valve covers. I will be disappointed if I can't get at least a foot of runner length.
BTW, is there anyone in the NY/NJ area, or in the Ashtabula, Ohio area that would be willing to take a look at my design once I get a mockup?
Why can't somebody bring out a manifold like the LS6's, but designed for an LT1?
Originally posted by AdioSS
That is what I pictured when I was reading your post.
I think I'd like to build it in a semi-modular way so that runners and/or plenum can be switched out.
BTW, if anyone has an LT1 manifold that they aren't using, I need one to destroy for R&D purposes.
Originally posted by SSlammedlt-4
If i donate my intake manifold do i get something in return, If things go well? J/W
Well, if you agree to donate your manifold, understanding that it will get destroyed in the process, then I'll agree that if I ever manage to create a working and useful manifold that I will give you the second working model.
when the intake valve closes, the column of air has considerable mass and velocity, which translates into inertia. the column of air doesn't just hit the closed valve and stack up. it's inertia 'bounces' it off the valve and sends the column of air back towards the plenum. this is known as a reflected wave. when the reflected wave arrives at the plenum, it collapses and moves back toward the valve, which is known as the returned wave. when this always moving column of air gets back to it's starting position, the cycle is referred to as a 1st-order harmonic. when it repeats the cycle again, you have a 2nd-order harmonic, and so on. the number of harmonic that will occur before the intake valve opens will depend mostly on the amount time between intake valve closing and opening and runner length(measured from the intake valve to the plenum). naturally the longer the runner, the more time required to achieve each harmonic, and of course the higher the engines rpm: the less time available to achieve a particular harmonic. with each harmonic cycle, the column of air gains mass but loses velocity. as the harmonic number increases, you will lose some cylinder-filling efficiency at the tuned rpm, but gain some on either side of that desired rpm. 1st- and 2nd-order harmonics tend to have very good V.E. at or near the desired rpm, but have a sharp drop-off outside of a narrow band. thus they tend to produce high peak torque but have a "peaky" torque curve. 3rd- and 4th-order harmonics tend to trade peak V.E. for a broader (flatter) torque curve.
for practical purposes, 1st-order harmonic are not really achievable as they require very short runners and very high engine speeds. 2nd-order harmonics are generally achieved with single-plane manifolds and a lot of intake lobe duration(shorter interval between the valve closing and opening). 3rd- and 4th-order harmonics are what dual-plane and tpi manifolds are designed for (with the appropriate cam selection).
BTW, some aftermarket intakes are being made with plastic. I saw a 3-piece design in the back of a magazine. Very simple concept. I think it would actually be possible to make one of those, using something like clay for the molds and then vacuum-forming the runners, like some kids made stuff in high-school shop class, but with thicker plastic. Then, just find some thicker plastic for the header flanges, injector bosses, TB flange, etc.
Originally posted by mnorwood
If you're looking to put in an hour glass shape, then you're going to have the air just slow down again as the hour glass widens out. However, maby (just guessing) it would have some benefit to air/fuel mixing, if the injectors were before the venturis.
I'll be out in Ohio in the near future. I used to work in the testing lab at a place out there in Ravenna called Allen Aircraft. They make mostly fuel pumps and valves.
Anyhow, the old man knows a whole lot about fluid dynamics, and I mean in an old-timer way.
He used to win those mileage races...
Anyone remember those? You get a small amount of gasoline and whoever makes it farthest wins...?
Well, he used to win those races with a dual quad corvette.
I'm going to stop in there and talk to him. Maybe talk to the engineers too.
I know that once air passes through a restriction in an otherwise constant sized tube, it actually continues to accelerate for a short distance.
I don't really understand why, and I know longer remember where I learned that. I only remember it being presented as an interesting oddity.
I think it had something to do with the vortices on the downstream side, that are created by the air passing through the restriction.
