How to check and re-assemble the oil pump?
Old Dec 21, 2004 | 12:21 AM
BlackLT1_TX's Avatar
I have mine pulled out to check specs, and install the "white" spring in my new Melling pump. Now I need some expert advice (since I need this to be right the first time.
First of all, what specs should I check, and what is acceptable?
Second, how do I go about re-assembling it? How much torque on the pump plate, should I use loc-tite, do both surfaces need to be really clean?
I cant get any good answers on something this specific elsewhere.
Thanks,
James
Old Dec 21, 2004 | 12:47 AM
SStrokerAce's Avatar
Re: How to check and re-assemble the oil pump?
Thanks,
James
Make sure it's clean number one. You should normally use a gear lube on the gears and tighten the 10mm or 8mm whatever they are down to 13 ft lbs. It's around that, i'd have to check the spec but there is one for that.
Bret
Old Dec 22, 2004 | 06:27 PM
arnie's Avatar
Check, and shoot for .0020", with a plus tolerance of .0005" clearance, for the gear end play.
Old Dec 23, 2004 | 11:11 AM
LT1ZZZ's Avatar
What pump do you have?
Old Dec 27, 2004 | 09:47 PM
FASTFATBOY's Avatar
Here is the procedure you are looking for:
Leave the stock spring in it on a stock engine, you dont need anything else, even on a modded engine
David
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
