Home thermal coating?
Old Dec 24, 2004 | 03:34 AM
oil pan 4's Avatar
Are there any thermal coatings we can do our selves?
I was just looking for some thing that could go on the rough exhaust ports of my cast iron heads I ported.
Ether coat them or just let carbon build up on them to insulate them.
Is there any kind of home thermal coating spary we can buy and do at home?
These are turbo heads.
Old Dec 24, 2004 | 12:30 PM
NOMAD's Avatar
Re: Home thermal coating?
There are several I do believe. Check www.swaintech.com I thought they sold one you could do at home with an oven, etc for small parts.
-Shannon
Old Dec 24, 2004 | 12:40 PM
Robs97Z28's Avatar
This would be the best place to buy from. They have been sell these kits for years... http://www.eastwoodcompany.com/jump....ORY&itemID=460
Old Dec 24, 2004 | 01:17 PM
Z28barnett's Avatar
I haven't worked with the coatings, but I would like to point out that carbon is not a good insulator. It is a electrical semiconductor, used to make cheap sparkplug wires and most resistors. Anything that tends to conduct electricity will conduct heat as well. Has to do with physics, and the free electrons.
Coating might do some good, carbon will not be as good as coatings and only a little better than bare metal.
You can't avoid carbon build up, but it won't help you very much.
Old Dec 24, 2004 | 01:21 PM
Hot Rod Hawk's Avatar
Nice powder coating kits but not what he's looking for, nor is THIS.
The swain link above is the "stuff"
Old Dec 24, 2004 | 07:57 PM
nosfed's Avatar
I've used the techline coating a couple times. We never did before and after tests, but it was still intact when the engines were disassembled.
Henson071
Dec 30, 2015 09:55 PM
30th Anniv Z28
Aug 1, 2015 10:39 AM
Bz8
Jul 13, 2015 04:46 PM
Boss002
Jul 9, 2015 03:33 PM
