Help with heads and cam for 383
Old Aug 9, 2002 | 08:02 PM
SnkEatr's Avatar
Lightbulb Help with heads and cam for 383
Since there are so many knowledgeable people on this board, help me out with this dilemna. I have a forged 383 assembled in my garage. the stock heads have a competition valve job, ferrea valves, and strong springs, but are not yet bolted to the block. I am thinking of using a Lunati hyd. roller cam with the following specs. Duration Int. 242 exh. 252, 110 LSA with 560 I/576 E lift w/1.6 RR. I plan on using a 58mm TB, and a 2800 TCI stall TC. OBD1 PCMforless programming. My question is this should i do more work with the heads (porting, polishing) I plan on having the intake and heads port matched. but already have the heads assembled. Will porting them make a significant power increase? I am trying to keep the car as streetable as possible, But want as much power as I can get out of this. What do you guys think? all help is really appreciated.
96 Black Z28 A4
Moroso CAI, Flowmaster 40
!MAF, HyperCrap Power+ for fan and shift firmness only, Hypertech 160 Stat.
2.73 Gears TAG SNK EATR
Best Time at Sunshine Speedway
R/T .501 <---- Dig That!!
60' 2.109
330 5.992
1/8 9.186
MPH 77.26
Soon to be a 383 Stroker
Wifes Ride Needing a BB
92 RS 25th Anniversary Ed.
Purple 3.1 V6/M5
Flowmaster series 40
Old Aug 9, 2002 | 11:03 PM
kmook's Avatar
Advanced Tech Moderator
Post
SnkEatr, This is definately a question that should be posted in LT1 Tech. I will move it there now.
Please checkout the link in my sig for more info, thanks.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
StansZ28
Feb 19, 2015 07:39 AM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
Black Sunshine/ 00SS
Jul 17, 2002 08:41 PM
