Help getting my intake to fit some milled AFR 220s
Hi guys,
I bought some milled LT4 AFR 220s for my 383 TT buildup, and I am having trouble getting my stock LT1 intake to fit. I posted a message on LT1 tech but all I got are the "use an LT4 intake" responses....
I was told the heads were milled down to 58cc (from 76cc) by AFR - so I am assuming I need to mill the intake down to match. The heads are already on the car because I was told the intake would bolt on without modification. I would like to avoid removing the heads from the car if at all possible.
Is there any formula to calculate the amount of milling required to the intake based on the 18cc per chamber reduction on the heads?
Thanks guys
Thanks guys
95chwagon
Jan 13, 2015 09:19 PM
