HEI distributor or edis
Old May 1, 2004 | 10:58 AM
sleeperz28's Avatar
Im to the point now where I want to change over and go either distributor in the rear of the motor or still run coils with the edis. I guess I really dont care which I do but it sounds like the HEI is the cheapest route. Those that run HEI what distributor are you using(p#) Are you running a crank trigger or just using the pick inside the dist? How are you pulling the dist in and out, did you cut the cowl or are you pulling the motor mounts everytime you pull it?
68camaroboltz
Oct 5, 2015 01:46 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
autoxr166
Sep 25, 2015 04:21 PM
1995Blackz28
Jul 20, 2015 09:34 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
