Which Heads for Stroker
Old Feb 19, 2005 | 08:05 AM
89385formula's Avatar
Well, I have finally sold my AFR 190's....I did that to buy a larger runner head to use w/ my engine. Now, I am looking to buy either a 210 or 215 runner head, Lloyd Is gonna port them and Bret Is gonna do the cam. I was going to get Trick Flow R-series 215's, but If Lloyd is gonna port them does it really matter which heads I start with? Theroretically, I would think that if it's an aluminum head it shouldn't matter which I chose because they are all about the same size runner, and should be able to be ported to the same extent, and flow close to the same numbers. Am I crazy for thinking that? I was looking around and found AFR 210's, The Trick FLow 215's, Dart Pro 1 215's, Pro-Action 210's or 215's, Edelbrock Victor JR's, and was wondering if it would really matter which ones I buy since they are being ported. I know the Trick Flows and AFR's perform much better "out of the box", but what about when they have been ported? What do you guys think, and/or choose? I haven't asked Lloyd or Bret this question because I don't wanna waste there time if it is a silly question, and they are very busy people. So help me out.[FONT=Arial]
Old Feb 19, 2005 | 02:36 PM
Re: Which Heads for Stroker
Doesn't anybody have an opinion on this?
Old Feb 19, 2005 | 02:52 PM
OldSStroker's Avatar
Ask Lloyd and/or Bret.
I know both of these guys. They want you to be a satisfied customer. I don't believe they will think your concerns are "silly".
A teacher once told me, "There's no such thing as a stupid question if you don't know the answer." I had asked a really dumb question, so he added, "...but that's close!"
Old Feb 21, 2005 | 05:18 PM
contactpatch's Avatar
What are the minimum cross-section-areas,
{of the intake tract} of the cyl heads being discussed?
Old Feb 21, 2005 | 06:51 PM
SStrokerAce's Avatar
The more important thing is that they are small enough so that when they are ported they will be the correct size.
Bret
Old Feb 22, 2005 | 04:11 PM
How is the 'correct size', determined?
Old Feb 22, 2005 | 06:27 PM
jnjspdshop's Avatar
It is pretty much determined by what you are looking for in an engine, and how you will be using it. Street -> Street/Strip -> Strip only. There are many factors which you need to consider.
Old Feb 22, 2005 | 10:16 PM
And what are those factors?
Kyle,
You are starting off with around the right size of castings if you are going for a mild port job. A 215cc port is a good place to start on what you are running, I can say that because we've talked about your combo already. You can base the port size on the physical cross sectional area, the effective cross sectional area or the port volume/port centerline average cross sectional area method but how you come up with a goal for those dimensions is the hard part.
Bret
Old Feb 23, 2005 | 04:00 PM
Well thanks for the hekp fellas, My mind is made up. Now i just have to buy them.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
