head stud questions ...
Old May 16, 2004 | 02:56 PM
bowtiepwr's Avatar
>I am using ARP head studs with my LT1 stroker motor (3.875" crank/ 4.030" bore) .
when the engine temp gets hot the lower head studs allow coolant to come up through the bolts ... I am pretty sure I put thread sealer on the theads that went into the block .
I know I definately put the thread sealant on the mid and long studs under the valve overs .
Do you think it's possible to remove the lower head studs and install more sealant on the lower head studs without having to remove the head or use a new head gasket ?
BTW there isn't any evidence of coolant in the oil .
Old May 16, 2004 | 05:11 PM
KCFormula's Avatar
IMHO I think you would be fine as long as you did them one at a time.
Old May 16, 2004 | 08:48 PM
sleeperz28's Avatar
You have to use orange RTV for your sealant or they will leak. You didnt use orange rtv did you? If you can dry out the bolt hole I dont c why you couldnt just pull the stud if you can get them out.
Old May 18, 2004 | 05:13 PM
bowtiepwr's Avatar
>I used ARP thread sealant .
thanks for the responses
Old May 18, 2004 | 11:20 PM
sleeperz28's Avatar
Yup start over with the RTV and you will never have to do it again. I made that mistake once, but never again..hahahaha
Old May 19, 2004 | 12:03 PM
Z28SORR's Avatar
I used liquid teflon not RTV and have not had any problems. However I must admit my engine runs very cool, maybe even to cool.
P.S. Thats in the 84 not the 97.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
Catmaigne
Dec 25, 2014 12:16 PM
