head porting ???
Old Aug 20, 2004 | 07:49 PM
bowtiepwr's Avatar
Question head porting ???
>I hope this qualifies for this section ... I have the AFR 195cc heads (#1031) that came with the 2.02 in /1.60 ex valves on my 94 Z28 that has a LT1 396 with a Vortech T-trim (no inter-cooler ... yet) , and N2O .
my question is should I get the heads ported bigger (8.5:1CR with 64cc now) and go with bigger valves or are these valves adequate for the size of my application ?
Old Aug 21, 2004 | 01:20 AM
MaxRaceSoftware's Avatar
Re: head porting ???
for a 396 cid SBC size engine i've used 2.080 to 2.125 OD intake valves
the 2.020/1.600 combo will work OK for a mild 396 cid SBC
but 2.055 or 2.080 will definetly make more HP if ported correctly
GM used 2.072" int valves in plain 396 BBC engines in 60's and 70's
and 2.190 OD on HiPerf 396 / 375 HP
GM LS-1 & LS-6 heads along with AFR LSx Cylinder heads respond very well
to 2.055/1.600 or 2.080/1.600 combo even on 346 cid
oldschool
Feb 9, 2016 09:21 PM
Dmonty
Jun 2, 2015 11:19 PM
cmyname1
Feb 19, 2015 08:38 PM
Roadie
Feb 16, 2015 10:34 AM
Killer94z
Jan 13, 2015 12:06 PM
