Geometry Lesson - Dwell Time
Old Mar 28, 2005 | 04:14 PM
Zero_to_69's Avatar
A longer Rod influences the piston to dwell a bit longer at TDC than a shorter rod would and conversely, to dwell somewhat less at BDC. This is another area where people often get the information backwards.
IE: piston 40 degrees BBDC to 40 degrees ABDC , compared with 40 degrees BDTC to 40 degrees ATDC
How / why does the dwell change between TDC and BDC? We are assuming
a steady crank rotation correct?
Old Mar 28, 2005 | 06:04 PM
marshall93z's Avatar
Re: Geometry Lesson - Dwell Time
why would it not have the same dwell time at BDC? doesnt make sense to me...
Old Mar 28, 2005 | 08:12 PM
jonaddis84's Avatar
Me either, unless it somehow has to do with stretching of the rod at TDC or something?
Old Mar 28, 2005 | 08:40 PM
Stephen 87 IROC's Avatar
Why do you even care what it's doing at BDC? Dwell time at the top affects how the fuel is burnt.
Old Mar 28, 2005 | 08:48 PM
Zero_to_69's Avatar
Because a longer dwell at BDC will allow a later closing intake valve (IVC) to increase effective
compression.
More charge into the compression and power stroke for more torque.
Old Mar 28, 2005 | 08:52 PM
jonaddis84's Avatar
compression.
I do know this much, unless you just want to know to know which is why Im curious. Youre talking an amount of time that is not even remotely worth worrying about in the case of 5.7-6" rods.
Old Mar 28, 2005 | 08:55 PM
Zero_to_69's Avatar
To know...is all I want to know.
I agree based on what I've read. But allowing the intake valve to close later
seems to be very important.
The next question after figuring out my first is why a shorter rod has more
duration at BDC than a longer rod?
The plot thickens!
Old Mar 28, 2005 | 09:00 PM
Zero_to_69's Avatar
OK, I think I have the short vs. long rod dwell figured out.
The acceleration time above 20 degrees before and after TDC/BDC is slower with a shorter rod.
That's easy to understand.
That allows us to close the intake valve a little later (~ 2 - 4 degrees according
to ISKY cams).
As far as the first question, I'm still drawing a blank.
Old Mar 28, 2005 | 09:15 PM
OldSStroker's Avatar
to ISKY cams).
Homework assingment time Tino:
Draw a schematic diagram of crank and rod. Crank pin turns thru 360 degrees, and large end of rod follows the circle. Small end of the rod (and therefore piston) moves linearally along an axis which passes thru the center of rotation of the crank (center of main bearing). The angle between the rod (center-to-center of the big end and small end) and the rod journal changes with rotation , of course. The trig is fairlyt straight forward, and doing a spreadsheet which calculates the distance of the small end of the rod from the crank centerline for every degree of rotation should be realatively easy to write. Make the stroke (or half the stroke, the "throw") and the rod length a variable, and you can "plug 'n crank" for any combination. Look at the last 10 degrees or so either side of TDC and BDC and you'll get your answers.
I'd rather teach you to fish than give you the fish.
It you have problem with trig and algebra, you 'll have to find someone who's already done this. "SEARCH" is your friend.
Old Mar 28, 2005 | 09:20 PM
Zero_to_69's Avatar
Way ahead of you Jon.
I appreciate the hints rather than the answer. I know I've been lazy in the
past, but lately, Google and I have spent many hours together.
There is an article which is touching on what you have just posted. Still reading
through it.
Thanks for the post!
http://yarchive.net/car/index.html
http://yarchive.net/metal/piston_acceleration.html
http://groups-beta.google.com/group/...b473fe43e32c17
Old Mar 28, 2005 | 09:52 PM
Zero_to_69's Avatar
Here's the first part of the homework assignment.
It's not quite to scale, but it's a visual for those wanting to follow along:
http://gmthunder.com/tino/rodangle.jpg
Old Mar 28, 2005 | 11:08 PM
jonaddis84's Avatar
Ok, I feel really stupid right now...trying to write up this excel worksheet to plug in stroke, rod, and compression heights and based on degrees of crank rotation output the piston height above crankpin centerline, and rod distance left to right of crankpin centerline.
Im just working on the piston height right now and for some reason my trig isnt coming back to me. If you know the angle at the crankpin (obvoiusly) say 75*, and you know the adjacent side (say 2"), and you know the opposite side (say 6"). What trig function would you use to figure out the last side?
And would you have to change the funtion for a different group of degrees, say after 180 or anything?
Old Mar 28, 2005 | 11:20 PM
Zero_to_69's Avatar
I'm in the same place you are.
The search turned up very little with respect to our needs.
I'm thinking of using Pythagorean's Theorum to find the piston pin centerline
above the crankshaft centerline.
From there we can assume a 90 degree angle along the cylinder bore vertical.
EDit: Scrath that!
I think I've got it!!!!
Without the math, here's the visual:
With the rod and crank arm at 90 ATDC, the rod is creating the biggest angle
at the piston wrist pin.
After the large rod end goes past the centerline, the piston is still moving closer
to the crank centerline.
The distance of the piston pin from centerline at 0' TDC is 1/2 stroke + rod length.
6.0" + (3.48 /2) = 7.74"
The distance of the piston pin from centerline at BDC is 1/2 stroke - rod length (absolute).
6.0" - (3.48 /2) = 4.26"
Thinking out loud....
angle of rod at TDC vs BDC +/- 10 degrees...rod and crank assembly is virtually 3.48" shorter at BDC.
That would explain the difference in time to move the piston when it's way
up in the bore, as opposed to far down in the bore.
Are we getting it Jon?
Math to follow tomorrow night.
Old Mar 29, 2005 | 12:08 AM
Zero_to_69's Avatar
revised diagram to show crank arm (green rectangle)
http://gmthunder.com/tino/rodangle2.jpg
Old Mar 29, 2005 | 01:07 AM
SStrokerAce's Avatar
Getting closer......
I'm sure he'll say something in the AM.
Bret
