Gearing selection re-re-revisited... :)
Originally posted by kmook
Wow Jim that racelogic stuff looks great from the info on their site.
But im curious for input on an unbiased source. Have you ever been in a car that has it? Or did you just drop the money on it hoping that it is good?
I sat on the fence for quite some time before I was convinced, but as far as I can tell, it's the least invasive traction control system the average consumer can buy. It's supposed to be nearly seemless in the way it cuts power, unlike the Supra's stock system, which slams a throttle blade closed and cuts air to the engine resulting in an almost complete bog. The Corvette's system is a little better, but still cuts power so heavily that it often results in a bog. This system cuts power but keeps the wheels moving at the set amount of allowed tire slip, so you're still making forward progress at the limit of traction.
Everyone who I've talked to who has used the unit says it's the best thing they've ever done to their car, next to making more power.
Originally posted by The Highlander
Why is the trans cheaper?? I always wondered that?? is it softer? will it break if ridden hard.. I remember that was the point...
Originally posted by jimlab
I guess I should have specified that I was talking about my car only.
Do you know offhand who has the best price on one?
Dammit now i want one
If there's enough interest, they can certainly start another group buy, assuming they become a forum sponsor. In the previous group purchase I urged Matrix Engineering to become a sponsor on both forums involved, and there was no problem with that. I'm sure they'd do the same here.
Standard price for the V8 system is as follows:
Racelogic Adjustable TC w/ ABS (Max 12cyl) - $995
Racelogic Adjustable TC w/ Launch Control & ABS (8cyl) - $1300
Racelogic Adjustable TC w/ LC, Data Logging & ABS (4/6/8cyl) - $1595
Full Throttle Shift option - $175
The full throttle shift option must be purchased at the same time as the system. It's not something you can easily or cheaply add later, if you change your mind.
Here's the contact information for Matrix Engineering. Jeremy Williams is the contact for RaceLogic systems.
Matrix Engineering Inc.
4060 SW Macadam Ave.
Portland, OR 97239
503.443.1141 Tech
503.443.1142 Fax
888.249.0013 Orders
jeremy@matrixengineering.cc
www.matrixengineering.cc
I think its cheaper to do it with the MSD and its the same thing...
RaceLogic's version allows you to hold an rpm that would normally result in tire smoke and the traction control system then controls the inevitable wheelspin during the launch. With the MSD, you can only launch at an rpm that's limited by tire type and available traction, and all it does is allow you to keep the throttle floored without over-revving so you can concentrate on the tree. No help with traction whatsoever.
Furthermore, it makes sense to get both the rev limiter and traction control in one package if you don't already have a two-step, doesn't it?
Highlander, it looks like Jim explained the Racelogic system quite well. Instead of keeping this topic going off in left field lets try to get it back on track. Maybe if you need further explination of the system, either contact Racelogic themselves, or send Jim a PM.
Thanks.
Thanks.
Damn those are very big tires!!!! they should weigh a lot.. which tires are theese?
I am considering getting some lightweight rims to put these on to shave several pounds.
I'm also considering putting some 295/65R15 BFG drag radials on the back
Re: Gearing selection re-re-revisited... :)
Thought some of you might be interested in seeing how this turned out. I finally found the time to finish my Cobra 8.8" IRS conversion.
The finished components (close-up) after powder coating, including my engine cradle. The Driveshaft Shop made the hybrid ('03+ Cobra inner spline, '93-'95 RX-7 outer spline) 300M chromemoly center shafts to my specifications. Here's a picture of the completed axle assemblies.
So this finally became this. A close-up of the suspension (polished), and the rear mounting bracket which ties into the stock differential mounting tabs.
I ended up going with a Zexel T-2R Torsen differential and 3.55:1 Ford Motorsports gears to start with. I didn't want to drop too much in the upper gears, and with the 2.97:1 first, I've got a final drive (10.54:1) almost equivalent to a standard T56 (2.66:1 first) with 4.10s (10.90:1 final drive). In other words, plenty of gear.
BTW, other 3rd gen. RX-7 owners liked the setup so much that I've already sold several copies and will be having another 5 or 6 made soon. Here's another picture of the "clones".
