File Fit rings on 383 SC
What are you guys setting your rings on 383 blower motors. My current set is: 383. 190AFR's, LT Hookers, 4" mufflex, 57# injectors, T-Trim w/aftercooler, and a TNT kit that I haven't sprayed yet. Probably some other stuff I forgot to name too, but anyway. See I'm trying to figure if mine weren't filed right cause my motor is getting blowby at 5500 and up and seeing 10# of boost, no more. I don't get any blowby at idle and none when I take the belt off the SC and run the motor up to 6400. The guy that did mine set the top ring at 20-22 and the 2nd18-20. I talked to the guys at JE/SRP and they told me they would set the rings at 26-28 for both. I have people telling me I should put a vacum pump on the motor, but I don't think I should have too.
Help. Fixing to pull motor and get New total seal rings and set the rings to the JE/SRP specs unless you guys got any idea.
GS355
GS355
I didnt want to say because I wasnt 100% sure ......but my engine biulder said you dont want to use the total seal rings with a power adder app. The tech guy also may have been refering to your ring land hieght of the particular piston your using as being for NA apps. Im using a standard NA -14cc SRP piston ....but I went to a 5.85 rod so that the wrist pin would be further from the land area. Your pistons should be fine if you are running 5.85 or 5.7 rods. Again I dont know alot about blower apps...only what Ive been told or read....so take my opinion for what it worth.
Total Seal
I kinda heard the same thing about the total Seal rings but I have watched first hand a stock LT1 withe the exception of the pistons and cam, go 630rwhp on 12#'s and some juice withe these rings. But we have discussed the hearsay about these rings, but I think I'm going to give it a go. But I will call the guys back at SRP/JE and ask the what rings they recommond.
Thanks GS355
Thanks GS355
Re: Total Seal
Thanks GS355
Thanks GS355
NewsBot
Mar 16, 2015 12:51 PM
NewsBot
Mar 13, 2015 07:15 AM
NewsBot
Feb 26, 2015 02:10 PM
NewsBot
Feb 6, 2015 05:00 PM
