figureing out how much flow my heads have
Old Feb 15, 2005 | 04:11 PM
tristan45331's Avatar
I have aluminuim heads from a 96LT1, I had them ported and polished.
I am wanting to know how to figure out how much flow and hp my heads will be able to produce. So that i can select a cam for the motor
Old Feb 15, 2005 | 04:42 PM
streetbad's Avatar
Re: figureing out how much flow my heads have
Since they are ported they'll flow lots. Take them to a place that has a flow bench.Total airflow is in Bowlingreen Ohio,I do not know where Greenville is. Be sure to get a big cam. Probably 50$ to flow one.
Old Feb 15, 2005 | 07:32 PM
OldSStroker's Avatar
Go to the person who ported them and ask for flow figures from .050 lift to at least .600 valve lift. If he can't supply them, by all means have an independent shop flow them, as streetbad suggested.
Just because they were "ported" doesn't mean they will flow lots.
Personally I'd talk with Lloyd Elliott (www.eportworks.com), and ask him if he'd flow them (for a price), then discuss the results with you. If they aren't what you want/need, ask him to quote his price to "fix" them. Lloyd can also fix you up with a cam that will work with your heads. IMO, you'd be farther ahead than choosing your own cam, and WAY ahead of just guessing without flowing the heads.
Old Feb 17, 2005 | 06:33 PM
Denny McLain's Avatar
Unfortunately based upon prior experiences, it’s almost always better to have heads independently flowed.
Lloyd is the exception to this. He’ll shoot ya straight and if they are good, he’ll tell ya and if not, he probably can fix them for something very reasonable.
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
smokin25th
Jan 1, 2015 09:06 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
