Is this even possible?
Old Jan 14, 2005 | 10:25 AM
Eff's Avatar
Eff
I was talking to a friend the other day. He said he was about to start on his race engine, as soon as he found someone to make him some spacers. I told him about a good local shop assuming he was talking about carborator spacers. He said no, he was talking about head spacers. Double gasketing a plate made to extend the cylinder volume. Doing this a larger stroke could be used or larger rods could be used to raise the rod ratio. I guess the deck clearence is basicly ignored and the piston can be brought up to right before the piston ring would contact the bottom gasket.
I don't see why this shouldn't work if done correctly, but I've never heard of it. My question is, is it worth it. I don't know what the thickness of the plate, or the stroke or sizes of the rods. He just told me it was bored .060" over.
Would this be a risk worth taking?
Old Jan 14, 2005 | 10:46 AM
SStrokerAce's Avatar
Re: Is this even possible?
There are instances where something like this would work, but you're not going to raise the deck of the block a huge amount.
Kaasse did this in his 2004 Engine Masters motor with a 3/8 thick head gasket. Then again his top ring was about .400+ down the piston.
If you were going to raise it considerably and run the piston rings up into the spacer then you should probably install a sleeve thru the spacer to maintain ring seal, that's about the only way I can see that it's possible.
Bret
Old Jan 14, 2005 | 10:54 AM
Rob94hawk's Avatar
I thought about this a long time ago using an LT1 but you would definetly have to use sleeves but you would also be tearing into the waterjackets. It would be cheaper just to buy a bigger block.
Old Jan 14, 2005 | 11:11 AM
Eff's Avatar
Eff
Never thought of that... Thats a lot of extra machine work, but it's a good idea.
I think his plan was to use a piston, like the one you mentioned with a considerable distance to the first ring and then he'd probably leave about .020"
between the ring at piston TDC and gasket.
Old Jan 21, 2005 | 12:47 AM
1racerdude's Avatar
Spend the bucks and get an after market tall deck block. To much brain damage otherwise.
Old Jan 21, 2005 | 05:18 PM
Eff's Avatar
Eff
Well yeah that would be the best way of doing it, but it may be hard to find.
