Damper Types
Old Dec 24, 2003 | 12:28 PM
LameRandomName's Avatar
Damper Types
While doing the research for my next motor I came across what appears to be a "quiet controversy" in regards to dampers.
One school of thought says that for a drag racing motor you should never have a dmaper that contains moving internal parts, such as a heavy silicone fluid. The reasoning is that since the motor is moving through it's RPM range so rapidly, the "moving parts" never have a chance to get into harmonic synchronization with the vibrations that are transmitted through the crank's snout, and that they therefore never actually manage to do any damping.
The other school of thought says that regardless of the use the engine is put to, the RPMs are still going to be moving up and down and that a damper that has moving internal parts is going to be able to "synch" with the engine so rapidly that it wont matter anyway. Plus of course, there is the fact that even if this were to be an issue with a dedicated drag racing engine, it wouldn't apply to street/strip cars that are actually driven on the road.
I was wondering if anyone could shed some light on this sissue for me, specifically in regard to the effectiveness of a damper such as the Fluidamper, since that is exactly the sort of damper that I had thought for years was the best kind you can get.
Old Dec 25, 2003 | 07:41 PM
InjectedSS's Avatar
FLuiDampr's are good for UP TO 6K RPMS
ATI SuperDamper is better for ABOVE 6K
personally i went with that FLuiDampr Since I only hang out at RPMS up to 7K so it made more sense to get that one... I like it, can't really tell any difference but I guess it's proven somewhere so its gotta be doing something
Hal Fisher
Sep 30, 2015 09:03 PM
CARiD
Sep 30, 2015 05:44 AM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
