D stroked LT1
Old May 3, 2003 | 11:40 PM
sprayed97Z's Avatar
D stroked LT1
Wondering if a d stroked LT1 has been done?results?Just thinking of doing something not so common.Thanks
Old May 4, 2003 | 01:46 AM
Dr.Mudge's Avatar
Its been done, but very rarely - because most people dont want to give up power without a reason. If your in a racing class asking 310 cubes or less for example, you probably want another engine/block anyway.
You will either build up the car for say 9,000 RPM ($$$), or else your wasting power by throwing the cubes away. If you want to be different, put a Honda engine in there, nobody has done that yet I bet.
Old May 4, 2003 | 01:49 PM
sprayed97Z's Avatar
Just a question.Guess I'll go ahead with the 396.I just like being informed.You know it doesnt hurt to ask a dumb question every now and then.Man that $6500 is gonna hurt.
Old May 4, 2003 | 06:51 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
correction: $13,000 is going to hurt, dont you know the golden rule?
figure out how much money and double it
tripple time
Old May 4, 2003 | 08:29 PM
mineralwater's Avatar
aren't some of the LT1s found in the caprices' destroked? the baby LT1?
Dr.Mudge's Avatar
My response was a bit sassy (Honduh), but destroking the engine has no real value. If I were strokin' it I'd go 383 probably, although the 396 sure has a nice historic ring to it.
Old May 6, 2003 | 11:42 PM
AdioSS's Avatar
West South Central Moderator
Yup, the "Baby LT1" is called the L99 and was only found in some 94-96 Caprice sedans. The wagons, Roadmasters, Fleetwoods, and Impalas never got this engine.
Personally, I think GM should've offered this in the S10s since they use the same tranny and rear end.
Old May 7, 2003 | 12:00 AM
TriPinTaZ's Avatar
tripple time
Damn aint that the truth.....I planned on about $6000 for my stroker project...............$16,000 later........... God Im depressed now and I still need a 12 Bolt REAR!
Old May 8, 2003 | 10:12 AM
stewmeistr's Avatar
Unhappy
Yes, It is absolutely the truth....
Sadly.
STEW
Old May 8, 2003 | 11:19 AM
treyZ28's Avatar
hmm, i bout my car for around $6,000
expected new brakes and Intake/exhuast
$20,000 later i'm still looking for tuning, converter, rear and tme to swap heads
Old May 11, 2003 | 02:02 PM
Chrisbequick's Avatar
A d stroked motor will totally d stroy your torque, which will have a d trimental effect on your launch, and will d ny you that stong bottom end we all d sire. It might de difficult to d termine what type of crank to use, as well. If I were you I would d molish any plans you have of d stroking.
-Chris
Old May 12, 2003 | 04:47 PM
AdioSS's Avatar
-Chris
LOL
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
transam_388
Mar 15, 2015 11:53 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
