CRAP! Engine balancing!
Old Jan 29, 2003 | 12:50 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Angry CRAP! Engine balancing!
I just thought about this guys-
my machine shop balanced my rotating assembly and didn't number (or assemble) my rods and pistons.
Also I used a different flexplate and harmonic balancer
am i in trouble?
6700rpms?
Old Jan 29, 2003 | 02:16 AM
SStrokerAce's Avatar
First,
If the pistons and rods all weight the same and are balanced you should be o.k.
2nd, if this is a LT1 motor I would make sure that the Flexplate is neutrally balanced.
If the rods are in two pieces, meaning that the cap is off and you got them back like this REPORT THOSE MFer's to anyone who thinks of going there and us, I'll give them a good what for just for that B.S. The rods only go together one way with one cap, they are honed that way and they are only accurate that way.
If your rods and pistons are pressed fit pistons, you need to go back and have them put together, if they are bushed then you can do it as long as the pin fit is o.k.
What are the parts you are working with anyways?
Bret
Old Jan 29, 2003 | 07:02 AM
treyZ28's Avatar
I think you misunderstood what I poorly communicated.
I meant he didn't put he rods and pistons together to balance them.
He also didn't need my harmonic balancer.
Its nuertrally balanced and so was the original one-
it has the wieght welded on it
sorry
Old Jan 29, 2003 | 08:09 AM
OldSStroker's Avatar
Originally posted by treyZ28
I meant he didn't put the rods and pistons together to balance them.
In order to determine the correct "bob weight" which is bolted onto the crank throws during the balancing, the rod big end and small end weight have to be determined separately. This is done without the rod being assembled to the piston.
Old Jan 29, 2003 | 09:16 AM
Gripenfelter's Avatar
My engine builder balanced the motor so that it would work with most any stock flexplate.
That way if your flexplate ever needs replacing you don't have to balance the flexplate.
Old Jan 29, 2003 | 01:43 PM
99huggerorangeZ's Avatar
Question
i am going ot need my rotating assembly internally balacned also but when i do i just need to bring him the parts right?
i dont need to bring the block
Old Jan 29, 2003 | 01:54 PM
treyZ28's Avatar
correct
Old Feb 1, 2003 | 11:42 AM
Abdullah's Avatar
i have a question regarding block clearancing to accept stroker crank and/or longer rods, is this way below correct or there is other way to clearance the block? :
do i assemble the piston and the rod at a certain cylinder than i see where it hits the block then i clearance at that place and then clean the cylinder from the block's metal particles resulted from clearancing and then check for block/rod/crank clearance again? by how much clearancing is enough?
thanks.
Old Feb 1, 2003 | 05:00 PM
treyZ28's Avatar
thanks.
you need 6 1/1000's of an inch clearance at least too...
you have to notch the block if your stuff doesn't clear
a 383 and JE rods clear i think
thats the only combo i've heard of that clears
Old Feb 2, 2003 | 01:59 PM
bunker's Avatar
hehe, big end & small end, belive it or not those are actual technical terms for crank end & piston end
bunker's Avatar
I always thought its just an aviation term.
Old May 1, 2003 | 08:51 PM
94ZVert's Avatar
Did anyone ever address his issue concerning the flexplate? I still don't understand what must be done in order to make a flexplate compatible with a complete and internally balanced motor. I have a new 396, but the old stock flexplate, and seeing how the engine was bought as a crate I don't think the flexplate will naturally mate up to it. Any ideas. Thanks.
Old May 2, 2003 | 03:10 PM
Z28SORR's Avatar
There are two common types of balancing. Internal and external.
On an internally balance engine you do not need to give the machinest either the harmonic balancer or the flywheel/flexplate. They are balanced separately and in theory any harmonic balancer and any flywheel/flexplate designed for use with an internally balanced engine can be use.
On an externally balance engine you have to have the harmonic balancer and flywheel/flexplate balanced with the crank assembly.
This then becomes an assembly and the HB & F/F can not be interchanged with any other crank/engine without rebalancing.
HectorM52
Jul 30, 2017 11:46 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Nostang 96z
Sep 15, 2002 10:15 PM
