couple questions on my 398 lt1
Old Jan 22, 2006 | 06:38 PM
  #31
amean94ta's Avatar
Re: couple questions on my 398 lt1
Cylinder Head Volume 50 cc
Piston Head Volume (cc) Piston Head Vol
(cubic in.) 00.000 they are flattops made by je said to be 12.1 on a 58cc head
Gasket Thickness (in.) i have 039's on it now
(cubic in.) 49.673
Gasket Bore (in.) 4.100 gasket
(cubic in.) 03.565
Cylinder Bore Diameter (in.) 4.040
(cubic in.) 00.515
Deck Clearance (in.) decken to zero
Note: Neg. nubmer above deck, Pos. number below deck Deck Volume
(cubic in.) 00.000
Stroke (in.) STATIC COMPRESSION RATIO 14.934
OPTIONAL DATA
Rod Length (in.) Adjusted Stroke (in.) 02.939 i have 6" h beams and a 3.875 crank
Intake Closing Point (degrees)
this one they said in the post to put 68
Old Jan 22, 2006 | 06:42 PM
  #32
SStrokerAce's Avatar
I'm with these guys... you need more RPM for that compression ratio. Problem is you better have some strong parts in the bottom end. I don't really like solid rollers unless you fix the lifter bore placements in the block... that's just one more way to make the things live.
How about you just fill in:
Chamber Volume
Piston Volume (-5cc for example on flat tops)
Head Gasket
Zero Deck or Deck Height
Bret
Old Jan 22, 2006 | 06:46 PM
  #33
Mindgame's Avatar
That changes things a bunch!
The JE pistons you refer to (shelf set) are -5cc. With that data & the variables you have given (using the KB calculator) I get 13.8:1 static and 10.26:1 DCR.
That's why we have to be careful with posts like this...
Either way... you have what you have & I got your PM. Actually need to get back to some other PM's (sorry guys) so I'll get with you ASAP.
-Mindgame
Old Jan 22, 2006 | 06:49 PM
  #34
amean94ta's Avatar
cool then i am about right we originally thought it was around 13.6:1
Old Jan 22, 2006 | 06:53 PM
  #35
Mindgame's Avatar
Love the Duckworth quote Bret.
I wonder what Kenny Duttweiler would say about that one.
-Mindgame
Old Jan 22, 2006 | 07:15 PM
  #36
Yeah, I'm sure your one of the few people who know who he is too!
13.6:1 sounds much more in line with what I was thinking.
I'd put the actual IVC around mid 80's to get you just under 9:1 DCR
Bret
Old Jan 22, 2006 | 07:55 PM
  #37
1racerdude's Avatar
Using the IVC of 73*@.006 as quoted on Comp's site for the 306 I get 13.83 static and 9.86 DCR.
Old Jan 22, 2006 | 07:56 PM
  #38
yeah thats around where it is now, way to early
Old Jan 22, 2006 | 08:17 PM
  #39
1racerdude's Avatar
No,it's about 8:15Pm.
A bigger cam will help the situation a bunch and the 396 will eat a big cam up and keep the revs down. Keep in mind I am not talking in the 280/290 range but in the 250/260range on a 108+4 or possibly a 112+4 will get it done.
His heads probably will want a bunch of lift and some pretty long duration IMO.
Old Jan 22, 2006 | 08:46 PM
  #40
Mindgame's Avatar
Lightbulb Re: couple questions on my 398 lt1
Then you have a miscalc nested in there somewhere. What is your calculated dynamic stroke length?
AFAIC, I'd cam it to spin 7200 and put the right fuel in it to keep it from going over the edge. Enough octane can cure just about anything.... for a while.
-Mindgame
Old Jan 22, 2006 | 09:56 PM
  #41
1racerdude's Avatar
-Mindgame
You are right. I didn't put the +4 on the cam.
Old Jan 22, 2006 | 10:03 PM
  #42
amean94ta's Avatar
whats this 108+4 and 112+4 never heard of that is it advance ground in?
Old Jan 22, 2006 | 10:15 PM
  #43
1racerdude's Avatar
Yes, but it isn't ground in it's the placement of the drive dowel pin.
Old Jan 22, 2006 | 10:17 PM
  #44
marshall93z's Avatar
Then you HAVE heard of it!
And that SCR sounds ALOT more realistic! I was thinking, "damn, how'd he get 15:1??"!!
Old Jan 22, 2006 | 10:19 PM
  #45
amean94ta's Avatar
cool so say 112 lsa you want a +4 i always thought the more radical cams were low like 106's
