Controlling aftermarket injectors with factory PCM
Subscribe
Dec 10, 2002 | 08:38 PM
1) If I want to machine a manifold to mount a roots type blower on an LT1 and control 8 individual injectors with the factory PCM, is that doable without major R&D? In other words, except for maching the manifold, is this an "off-the-shelf" type of job?
2) If I chose to do this and I machined mounting points for individual injectors by each intake port, are there guidelines in terms of mounting and aiming the injectors? Distance form the head, etc?
Reply
Dec 10, 2002 | 08:52 PM
The only problem is to see if the cables are long enough or not to fit.. the rest.. I dont think it matters to the PCM where the injectors are...
Reply
Dec 10, 2002 | 09:17 PM
Well cable length is a non isssue to me. I can always make a wire longer.
I think I was more concerned with what went into deciding the location of the injector in relation to the entrance to the intake port.
Reply
Subscribe
