Connecting Rod Side Clearance
Old Jun 18, 2005 | 04:41 PM
  #16
Mindgame's Avatar
Re: Connecting Rod Side Clearance
Originally Posted by arnie
Not regarding Eagle cranks specifically, but cranks in general; this is where the novice gets himself in trouble. They use a crank with larger (stronger) journal radii, but attempt to use rod bearings that do no allow for (have the additional clearance for) that extra material of the larger radius. They end up riding on the radius and wonder why they have problems. Hmmm.
You mean they make a narrower rod bearing to account for this? Who would have thunk it.
-Mindgame
Old Jun 18, 2005 | 04:55 PM
  #17
SStrokerAce's Avatar
Hmmm, apparently you are not aware where the side of the rod makes contact with the crank journal.
See the edit above:
I hope you are not telling me you can, or expect to 'ride' on the radius of the crank journal.
You testing me? This is crank tech 101.
No I get ya there but side clearance is usually measured between the rods... so a narrower rod journal will in turn close that clearance.
Bret
Old Jun 18, 2005 | 05:01 PM
  #18
arnie's Avatar
Wanna know what I think? I think you and MG are in cahoots on this.
Old Jun 18, 2005 | 05:02 PM
  #19
Mindgame's Avatar
Cool Re: Connecting Rod Side Clearance
I cahoot with no one!
-Mindgame
Old Jun 18, 2005 | 08:59 PM
  #20
I could be wrong too..... Either way I wouldn't stress about it and it's not easy to fix.
Hell I found some SB2 bare castings on ebay but once I noticed that they were not SB2.2's I knew why they were so cheap..... if they were 2.2's I would have been in cahoots with MG.
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
