Cadillac "16"
Old Jan 15, 2003 | 05:58 PM
mongse_1's Avatar
Cadillac "16"
Anyone know how it works besides, "the crank turns which pushes the pistons, which..."
Supposedly, under idle and normal driving conditions, it operates under 4 cylinders. On acceleration, it uses 8 pistons. A WFO, it's on all 16. It also makes 1000 hp & 1000 #/ft on 16 cylinders and gets 20mph under normal driving conditions(i.e. 4-cylinders).
We had a debate about this today @ work and I'm thinking it's done through managing the fuel/spark based on engine RPM.
Any ideas/guess/facts?
Old Jan 15, 2003 | 06:12 PM
Mindgame's Avatar
What you're referring to is called 'displacement on demand' or DOD. If you do a search on that subject you'll find quite a bit of interesting reading info. The way I understand it.... the 'shut down' is controlled in the valvetrain and of course the computer does it's thing to ensure no fuel gets sprayed in the dormant cylinders. Probably cuts spark too but I'm not to up on all the details.
Here's a link (.pdf) of some of the componentry:
http://media.gm.com/division/powertr..._on_demand.pdf
-Mindgame
Old Jan 15, 2003 | 09:47 PM
mongse_1's Avatar
Thanks. Looks like I was pretty much right.
Old Jan 16, 2003 | 08:21 AM
OldSStroker's Avatar
The "16" came up a week or so ago on this forum. Here's a pic:
http://popularmechanics.com/automot...llac_engine.jpg
It's 2 valve per cylinder pushrod engine, with about the same hp/liter as a LS6. To my mind the heads look very much like LS1s
(only longer!)
The cool thing about DOD is the simple way of shutting down the valve by holding the lifter collapsed with oil pressure.
Old Jan 16, 2003 | 08:32 AM
kmook's Avatar
Advanced Tech Moderator
Linky no worky...
Old Jan 16, 2003 | 08:56 AM
Try this one:
http://popularmechanics.com/automoti...3/index2.phtml
Click to enlarge the engine.
It worked when I tested it just now.
Old Jan 16, 2003 | 11:05 AM
mongse_1's Avatar
Now THAT'S a header!! Looks like the alternator is not driven off the crank either...hmmm.
Old Jan 16, 2003 | 05:33 PM
AutoWeek says the 16 engine "weighs less than a standard GM V8 of today." I think they mean a iron block V8 like the 8100
830 cubes get MY motor running!
Old Jan 16, 2003 | 06:03 PM
kmook's Avatar
This is great-
http://popularmechanics.com/automoti..._auto_show_13/
Old Jan 16, 2003 | 07:10 PM
Originally posted by kmook
This is great-
Ain't it though!
Wayne Cherry's swan song as head of "GM Styling".
How 'bout those 24 inch wheels?
Old Jan 16, 2003 | 07:18 PM
Mindgame's Avatar
All that power and '22 mpg'.... aint technology grand.
I don't know if I'm ready for a Cadillac (or will ever admit it) but Caddy has some neat ideas. I'd go for the Cien in a heartbeat though... even if I was sporting the silver mop.
-Mindgame
Old Jan 16, 2003 | 11:10 PM
mongse_1's Avatar
If the 24s even come close to making it to production, it'll be by the hand of God. lol
I'm thinking 18s at the most. Of course, we all remember the Prowler.
Mandatory first mod....turning the accuators on to run 16 cylinders all the time.
brothaslide
Jan 9, 2016 12:11 PM
Jul 17, 2015 02:47 PM
ChrisFrez
Jan 4, 2015 08:43 AM
mark0006
Dec 25, 2014 09:50 PM
NewsBot
Dec 3, 2014 12:30 PM
